Non Hydraulic presses
Does anyone know of any plans available for theses presses?
I'm thinking along the lines of a simple heavy rotating flywheel that works similar to a power hammer, but where the top die would have no springs or shocks. The flywheel would turn and move a concentric shaft up and down with say a 1/8 " throw. The bottom die could be moved up and down with a flypress type screw. You could just insert the billet, spin the screw up and walk the billet. Does this make sense? |
I'd say if you happened to have the billet to cold something is going to brake
that's the short of it...other things :( can happen also |
I don't know about plans, but there are such things as fly presses that work as you describe (I think). Here's some examples: http://www.oldworldanvils.com/flypresses/index.html
Quote:
3 HP motor! This is sounding better all the time, fellas.
| All times are GMT -5. The time now is 11:31 PM. |
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© Copyright 1998-2010 BladeForums.com. All rights reserved.
BladeForums.com is an adult website with adult discussions.
In accordance with the COPPA, no one under the age of 13 may join BladeForums.com
