Results 1 to 7 of 7
Thread: Going from knives to razors
    Hello,
    I need a little help, well lets start with a short story...
    Since i only shave once in a while, my hairs always get stuck in between the blades of usual razors, which is very annoying. Electric razors either dont cut longer beards at all or dont shave very smoothly. (talking about 2-10mm length mostly)
    I like knives a lot so i was thinking to learn to shave myself with a knife however, im poor so i didnt have too many knives to choose from. A big 30Cm D2 knife or Opinel nr.7 carbon were my choices.
    I decided for the opinel and mirror sharpened it with around 10° per side to get as much sharpness out of it as possible. i could split a hair by length after stropping and started shaving with my usual foam. Cleaning cut hairs was much easier, and the shave very comfortable, even though i had to pay a lot of attention especially around my ear with the curved tip.
    when i was done with half of my face the Opinel started to tug significantly, i tried to strop it but it didnt help too much. i didnt have anything else to use so i just dealt with it and shaved anyway (kinda hurts) in the end it was dull, just as i have expected.
    Even with all those complications i found it much better and so i decided to buy 1) a proper knife 2 ) an actual traditional razor
    If there is a knife i could use to shave regulary while also EDCing, ill do that. But i would still probably buy a razor to learn it with a proper tool first.
    Of course being me i was searching for a good steel and everything to make a good quality purchase for a knife leaving me with M390 since i really dont want to deal with rust and like mirror edges.
    "If i can shave with a knife with a 35° angle made from high end steel, then a razor from the same steel must be even more comfortable and i might not even have to strop it" Or so i thought.
    Then i decided to search in my favorite online shop for a razor starting in the lower prices and SURPRISE! There were no informations about steel whatsoever. "well thats with cheap knives the same" i was thinking and so i went to a higher price range.. higher.. and higher..
    Yet the only information there was "high quality stainless/carbon steel" even in thousand dollar price ranges.
    Does the steel of razors not matter at all or whats the deal? This question is the main reason why im here asking it.
    And finally, could you recommend me a good quality cheap razor? what should i look out for/pay attention to, if not steel?
    Anything else i should buy with it?
    (definately stainless, im from europe, budget is around 40$ but i dont mind being talked into something if its worth it, afterall a razor should only be bought once)
    Thank you everyone for your help (i cant believe this is the second thread in this topic) im aware of razor forums existing but i decided to first used the forum im familiar with.
    I would get an old Double Edge Gillette Razor. You can get 100 Astra or 100 Personna Blades for around 10 bucks. I use an Old Gillette Black Beauty Twist to open, which is also adjustable.
    If you get an old Twist to open, or even a new one, they will need to be cleaned out somewhat regularly. For that, hit the easy button. I spray my down with Safariland CLP, inside and out. Twist em open and shut a few dozen times, then rinse it out thoroughly with hot water, then drop it in a glass of distilled water for a few minutes.
    Easy peasy.
    And I would recommend shave soaps and a decent Plisson or Plissoft brush, and mug over canned shaving creams or gels. You can get a razor similar to mine, a nice vintage shave mug (I use an old Hazel Atlas Milkglass Shaving Mug...but a Porcelain Cappuccino Mug will work very well also) an awesome Razorock Plissoft Brush, and a puck of shave soap for $40ish all told, if you know where to look.
    I paid $20 for my Gillette, $10 for my mug, and $12 for the brush I'm currently using.
    For soap, I use and love Williams Shaving Soap. Many hate it, because they don't know how to lather it properly. Mind you, I have other creams and butters. But when you learn how to use Williams right, that heavy, tallow based lather is unbeatable. It is heavy, long lasting, and SLICK! The scent is very faint as well.
    If you want a straight razor in addition to that, there are some good shavettes out there, that can hold the same double edged razors that your safety razor uses. They are great for detail work. And again, for around $10 you can get enough quality blades to last you for more than a year. There are some great shavette razors out there than can be had for less than $20.
    I'm not knocking straight razors, but a quality straight razor is going to cost more than $40, and they require a LOT of maintenance.
    Quote Originally Posted by ursamajor View Post
    Easy peasy.
    Cool thank you for your tips!
    Yeah straigh razors are more expensive but i wouldnt mind spending more if it was worth it. Maintenance is fine as far as stropping sharpening goes, i do that with my knives as well. I wouldnt want a carbon steel razor that has to be oiled after each use, that would be bothersome
    May 2007
    Sunshiny coast of Oz
    4,541
    Apart from a few custom makers, its very uncommon to find the actual alloy of the steel. Its either stainless or not. The reality is that it doesn't matter, as long as the manufacturer has done their job, and spending more to know what the alloy is, is just a waste of money. Also, unless you plan on storing your razor in a very high humidity environment, carbon or stainless doesn't much matter.
    shaving and knives have very little in common, a comfortable razor will be a terrible EDC and vice-versa. If you do want to go with a straight, then a whipped-dog is likely your best bet on a budget. Good vintage razor at a decent price. If you want to spend a couple hundred, then a Dovo, or similar would be good, but there are many razors on the market that are more for fashion than use, although this has dropped off some as the fad of straight shaving had died down some.
    As for an actual cost breakdown, you should expect to spend around 100usd for the razor, 75USD for a good strop, then either will have to buy stones (several hundred) or pay for honing (there are several good razor honemeisters in Europe, they can be found at straighrazorplace) A used Double edge and 100 blades will run you 50-75USD, and be much less trouble. Don't get me wrong, straight shaving is pretty awesome, but when it comes down to it, you won't save time or money. DE is the cheap way to go.
    As for traffic to this corner of the forum, it just gets less traffic, feel free to ask questions as there are a few of us who will drop in to answer them, there just isn't much to talk about otherwise.
    Quote Originally Posted by gadgetgeek View Post
    Thats very surprising. Its always said "this knife is as sharp as a razor" and i lived with the idea that razor guys know much more about sharpening and steel types than us knife guys, after all razors are some of the sharpest blades in the world. To even go as far as saying that carbon or stainless doesnt matter really surprises me. Is it just the grind that matters then? I mean in knives the difference between k390 and 1095 is very big as far as stropping and edge maintenence. I imaged on a very keen razor edge this would have a much larger impact.
    Anyway thank you for the price breakdown it seems very realistic. Ill have to let it go through my head some more.
    May 2007
    4,541
    Carbon vs stainless matters for honing, and a bit for longevity, but use, not so much. temper and geometry make a bigger difference overall. Its not that razor collectors and users don't care, but more that companies like DOVO have been using the same steel for so long its not worth their time to call it something special, kinda like how mora and vic used to be. And since the large bulk of straight razor users are using blades made between 1870 and 1970, there are other things to consider. The shape of the abrasive used to hone can make a difference to the feel, we are talking tolerances on a microscopic level, where final edge really matters, where as which an EDC your overall edge geometry and other factors are going to play a big part in how "sharp" an edge preforms. Its more complex than that to a degree, but in different ways to EDC knives there things like carbide size and stability can be factors one looks for, and to the best of my understanding razors want as little and as small of carbide as possible. Its also very subjective.
    Yes that all makes sence. So it seems that the modern steels havent got into the world of razors, there is probably very little demand too. Carbide size etc. is what i was looking for in a good steel for a razor. With todays tech like a microclean stainless steel, could need very little maintenence while delivering a good shave i think. I guess what you said for honing explains why razor strops are so expensive while knife strops can be anything. Very interesting
