Results 1 to 13 of 13
Thread: Water under scales
    Aug 2015
    Summer MO, Winter TX
    208
    Water under scales
    I cut up a slab of ribs last night using my 632 Mesa with Micarta scales. After use I washed the knife in water, dried it and set it aside. This morning I got to thinking about water seeping under the scales. I removed the scales to find a seemingly abundance of water. I wiped it off and sprayed a bit of WD40 and put the scales back on.
    I realize the blade material is stainless and the Micarta is nearly indestructible but water left in a non ventilated place has to cause problems at some point and I refuse to remove the scales every time I wash the knife.
    Hello 100 series.
    Oct 2015
    Looking for Buck folding Kalingas.
    1,881
    You could glue them to keep the water out
    Buy membership.
    Sure an easy fix. DM
    Oct 2015
    1,881
    Maybe a rubber gasket sheet cut to fit.
    Buy membership.
    Mar 2011
    West of the Mississippi, South of the Missouri and North of the Meramec
    2,674
    Just curious, what kind of glue would you recommend?
    "The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt."
    - Bertrand Russell
    2 part epoxy. DM
    Jun 2009
    VA
    3,834
    You could apply a thin layer of clear silicone or even a coat of petroleum jelly and reattach the scales.
    BCCI Lifetime Member # 2068
    U.S. Navy 1978-86
    That would work as well. DM
    Oct 2015
    1,881
    Maybe an air compressor?. Wouldn't take much to dry it out. I don't know of a full tang knife with removable scales wouldn't get water under in them.
    Buy membership.
    I agree. I think I would try a good coat of Vaseline/petroleum jelly on the tang and put the scales back on. This should work. But, if it is not satisfactory, I would try silicone. I would do these before permanently gluing down the scales.
    Aug 2015
    208
    The scales seem to be tight, no gaps and holding it up to light I can't see any space between scales and tang. I'm thinking perhaps the water is getting in around the screws. If this knife is to be used for general purposes I need to get the leak fixed or put it in a drawer and use the 119. I will try some of the things suggested and see what happens
    Jan 2005
    Elizabeth, Colorado
    1,389
    DDDWho, don't know if you have seen this thread. http://www.bladeforums.com/forums/sh...32-Mesa-Knife/
    The Mesa seems to be designed as an outdoor knife, not a kitchen knife. If used in food prep then washing and drying it after every use should be expected. If a knife with removable scales is used for food prep, spraying with WD 40 doesn't seem like a good idea...JMHO.
    Yes, the 119 would be much better in 'general purpose' use. It wasn't designed as a kitchen knife either but would be easier to clean. Preston
    Mar 2001
    Hayden, Idaho, United States
    635
    We don't recommend cleaning with water. Bad things can happen. you are better off wiping most of the BBQ sauce off and then using a mild spray cleaner that evaporates. to finish it up..
    Jeff
