Is the plan to buck and split wood for the fire ?
... or split wood that was bucked with a saw?
I may be in Alaska for a few months.
Let’s forget for a few moments about hatchets and axes. What Tomahawk would be better for winter (all night wood)? I tend to leave the machete home for winter backpacking trips and I don't care much for the weight of axes- not going to be building any log cabins.
I own and love the CS Frontier Hawk with a cut down 16” handle.
Would you say a heavier Hawk head or a longer handle would be better for winter at elevation 4,000-8,000 feet? Our snow line is around 5,000 ft in CA.
Thanks in advance, pictures would be much appreciated.
-RB
Guess you only need some little Blue pills then.
I would say either the one you've got there or the trail hawk. I own and have used both up here in Maine which isn't too far off climate wise from where you'll be.
I personally would probably go with the trail hawk. The shape of the head as well as the extra weight make the trail hawk a little better at splitting, plus you get the added utility of the hammer.
That hammer is also handy when your hawk gets stuck because it gives you something to pound on to drive it the rest of the way through, effectively making your tool into a three-in-one: hawk, hammer, and splitting wedge. The frontier hawk is lighter though and is definitely no slouch either.
Then I'd say a heavier head would do more work and save you time.
I have a Riflemans Hawk that you can have if you want it.
http://www.coldsteel.com/riflemanshawk.html
The bit isn't much thicker than the Trailhawk and it weighs over twice what the Trailhawk does.
It weighs more than most hatchet heads also.
The bit is thinner than the GB Hunter that I have.
It's a lot hawk for that size handle.
Chops pretty darn good.
It's a beast as far as Hawks go IMO.
I have a lot of hawks but for all out wood processing the one on the right would do he best out of my hawk collection
Steve from Coal Creeck Forge made it
If this is for high elevation Alaska use, wouldn't you want an axe with the bigger blade? Seems like you'd need to expend too much energy using a 'hawk for real axe work in the winter. If you plan to stay with just a 'hawk, I think you need a longer handle so your swings are more efficient. Just a little more weight to the handle can save you many extra strokes.
My fear of high altitudes and extreme cold is working-up too much of a sweat from over-exertion and freezing.
Originally Posted by Bastid
-Convincing knuckleheads that the real key tool lies between the ears in creativity, application of common sense, adaptation and thinking out of the box might just be a losing battle.
