Results 1 to 10 of 10
Thread: Help with 118 dating and steel
    Mar 2006
    Central NY
    1,420
    I bought a number 118, also known as the "Personal" from eBay. According to the seller it was made between 1973 and 86. Does anyone know what kind of steel was used and also what are the identifiable characteristics of this time period? I want to make sure the knife is what it's supposed to be. Thanks
    Can you post some pictures of the knife, its stamping, handle and sheath? This would help us give you the information you want. Buck changed steels during the time frame your seller states. Many collectors here are well informed on your model and can give you even more than you ask but we don't shoot in the dark. DM
    Apr 2010
    SO. CAL
    2,646
    Prior to the date code method of dating a knife, one would be able to date a fixed blade knife by the tang stamp, number of spacers in the handle and the material used to make those spacers. Your knife being supposedly from "1973-1986" is a bit incorrect. This doesn't surprise me, because Ebay sellers usually have no idea what they are talking about. So, my point is, if you are buying a knife off of the bay by only the description, you are already in trouble.
    1973 began the upright blade stamp. This means you can read the stamp with the blade pointed up. It should read BUCK 118 USA. That particular stamp ran from 1973 through 1885. In 1986 Buck began using the date code system. I prefer to try to keep things simple as far as dating a knife. Things didn't just start and finish in the first and last of the year. If you try to narrow things down to the month something happened you will never date anything, because most of that information isn't out there. Because your knife stamp ran for 12 years, we than go to the handle spacers for more information. From 1973 to 1981 the knife had 4 handle spacers. These spacers were made of Micarta. Earlier spacers used on knifes pre 1969 were made of a material called Bone Hard Fiber, and had a bit different appearance. In 1981 Buck began removing handle spacers. First they removed one in the finger guard area, then in the pommel. This left only 2 spacers, one in the finger guard and one in the pommel. So, from 1973 to 1985 there were 3 different configurations of the knife. Its not just cut and dry 1973-1985. I hope this short lesson helps, I'm not usually this long winded...
    The steel could be 440 or 425M depending on when in that 12 year stretch your knife was manufactured...
    BCCI LIFE MEMBER #2113
    "Guard with jealous attention the public liberty. Suspect every one who approaches that jewel. Unfortunately, nothing will preserve it but downright force. Whenever you give up that force, you are inevitably ruined." --Patrick Henry
    Mar 2006
    Central NY
    1,420
    The knife has 4 handle spacers that are a dark mahogany color. The sheath is a fold over button snap model, and it's stamped: Buck-118-U.S.A
    Apr 2010
    SO. CAL
    2,646
    1973-80/81ish, 440C if i'm not mistaken
    Mar 2006
    Central NY
    1,420
    Quote Originally Posted by mbjannusch View Post
    After you said 440 I was hoping it was C and not A.
    Apr 2010
    SO. CAL
    2,646
    Buck never used 440A
    Mar 2006
    Central NY
    1,420
    Thanks for the help. One last question. What would be a good price for this knife in unused condition, but with no box or papers?
    Apr 2010
    SO. CAL
    2,646
    If I was going to buy a 1973, 118 with just the sheath (no box or paperwork) I wouldn't spend more than $75 dollars.
    Mar 2006
    Central NY
    1,420
    I made out alright then. Wish I would have gotten in on the d2 build out. Thanks for the help.
