BladeForums.com
Specific | Related | Community | Makers | Manufacturers | Exchange | Archives | Help
Want to Sell Knives? Private Message? Post Polls? Upload Pictures?
Upgrade your forums experience, and help support this site.
Go Back   BladeForums.com > Manufacturer's Forums > Chris Reeve Knives
Notices
Chris Reeve Knives Maker of such knives as the Sebenza, Mnandi, Umnumzaan, and fixed-blade knives for the Quiet Professional. Products from Chris Reeve Knives are the epitome of high quality and attention to detail. Visit their website at: http://www.chrisreeve.com
Closed Thread
Thread Tools Display Modes
  #1
Old 06-15-2003, 08:32 AM
TedV's Avatar
TedV TedV is offline
Registered User
How I clean my Sebenza (with pictures)
Hi, this post outlines the procedures (with pictures) to take your Sebenza apart, where to lube it, and put it back together again.
The same text & pictures is now also available on the CRK site: http://www.chrisreeve.com/sebenzaclean.htm
The procedures have been fine tuned with comments from Chris & Anne Reeve. Below are the two quotes from them for dis-assemble and re-assemble
Dis-assemble:
Quote:
When disassembling a Sebenza, undo the pivot screw, remove it and the pin and then slide the blade out. You can see the pressure on Chris' thumb as he is pushing the blade left.
Set the blade aside, then undo and remove the other two screws and pins. This way is a little safer and overall it’s a bit easier.
Re-assemble:
Quote:
The handle must be assembled first and both screws tightend. Just comfortably tight (this applied to all the screws!). The blade assembly (blade, pivot and 2 bronze washers) is then inserted between the handle slabs. If it will not go in, you do not have it assembled correctly. Do not loosen the handle screws off. Once the blade assembly is in the handles, line up the pivot hole and insert the pin. The allen wrench can help you line this up. Tighten the screw into the pin. Flick the knife open once and you are ready to go. This is the only time flicking is advised!
But, pictures say more than a thousand words
Start with the knife closed
Then, unscrew only the pivot-screw (most-left in the picture), remove the screw, and with the allen-wrench, push/tap out the pivot pin.
Open the knife slightly, and then pull out the blade, as shown here in a picture from Chris Reeve. It will require a bit of force, but try to do it gently.
Then, unscrew the other screws and take everything apart.
So you get this
Then clean all the parts. CRK advises to NOT use any polishing materials.
Assembly the handles, with only the stop-pin+screw&pin and the backspacer+screw&pin. Screw them down normally tight, but not over-tight. The wrench is a harder material then the screws, so if you use to much force, you risk stripping the screws heads!
Leave that, and start oiling the blade. Put oil on the areas where the washers go, and inside the pivot area. Also put some oil on the tang where the lock bar normally engages.
  #2
Old 06-15-2003, 08:33 AM
TedV's Avatar
Registered User
Put the washers on the blade, and insert the bushing. They will 'stick' to the blade because of the oil.
Result:
Then align the blade/washers/bushing with the handles
and start inserting it into the handles. At first you might think that it doesn't fit, but it SHOULD fit! If it doesn't fit, you assembled it wrong, see message from Chris Reeve at the top.
You need to hold the blade in such a way that you keep the bushing in place with your thumb and fore-finger and then slide it between the handles.
Do not unscrew the stop-pin screw to make room. It should and will fit!
  #3
Old 06-15-2003, 08:35 AM
TedV's Avatar
Registered User
After it's inserted so far that the bushing is between the handles, you need to unlock the lockbar to slide it further. Then align the pivot hole from the handle with the blade pivot hole.
Hold it up against the light to see if it's properly aligned. Otherwise the pin won't fit. Don't force the pin in, it should slide in normally. Once it's in, put in the screw and screw down tight. Open the blade as shown:
Then, only once, you're allowed to (gently) flick the blade open, then close it and open it normally and it's smooth and lock up is tight and in the right spot.
A 'print version' of the procedures is available in this thread:
http://www.bladeforums.com/forums/sh...hreadid=263815
A very good video of the procedure, made by Danish Viking is available here:
click here
Good luck!
Ted
  #4
Old 06-15-2003, 10:54 AM
jsun jsun is offline
Registered User
Just wanted to say what a brilliant job you did with the pics Ted. They should have them up on the CRK site!
J
  #5
Old 06-15-2003, 11:44 AM
Gary W. Graley's Avatar
Gary W. Graley Gary W. Graley is offline
G2, that Leather Guy
Very handy reference, thanks!
G2
__________________
"The Road to Hell is Paved with Good Intentions!"
Take the time to read your Bible Now, don't be left behind...
Psalm 1
  #6
Old 06-15-2003, 04:08 PM
Louky's Avatar
Louky Louky is offline
Registered User
Thumbs up
Very nice photographs...
The relevant picture is better than a long explanation !
  #7
Old 06-15-2003, 04:14 PM
GigOne's Avatar
GigOne GigOne is offline
ad arma
Excellent tutorial ! Thanks !
Boy. . .I'm glad that I've been doing it right this whole time !
__________________
  #8
Old 06-15-2003, 05:15 PM
dylan_d's Avatar
dylan_d dylan_d is offline
Registered User
Would a tough cloth be good enough for lubing my Sebenza or should I pick up some militec? Also, is the CRK lube any better than militec?
  #9
Old 06-15-2003, 09:29 PM
stjames's Avatar
stjames stjames is offline
Sebenzanista
Nice job, should make a great reference.
  #10
Old 06-15-2003, 10:23 PM
GigOne's Avatar
ad arma
Someone needs to get with a Super Mod and have them tack this thread on the top of this forum.
I don't know how many threads that I've seen that asked the simple question(s) of how to put a Sebbie back together properly.
__________________
  #11
Old 06-15-2003, 10:33 PM
Junkyard's Avatar
Junkyard Junkyard is offline
I'll second that.
Jason
  #12
Old 06-16-2003, 12:21 AM
n2299 n2299 is offline
Registered User
Ted,
As a Sebenza newbie... I would like to thank you for a most informative post.
Cheers!
  #13
Old 06-16-2003, 12:44 AM
TheBadGuy's Avatar
TheBadGuy TheBadGuy is offline
Registered User
Ted, with your post, I will now disassemble my Sebbie for the first time. Technical explanations are great, but your pictures and simple instructions are just what I needed to gain confidence and not worry about crimped washers. I thank you and my EDC thanks you
  #14
Old 06-16-2003, 01:35 AM
TedV's Avatar
Registered User
Glad I could be of some help. I'll try to update the picture off the parts, it's a bit fuzzy.
Dylan_D,
I explicitly left out details on how I clean and oil, because everybody seems to have it's own preferred way.
(And I don't know the english words for the cleaning stuff that I use
But, about your question,
A Tuff (Sentry Solutons) (I guess you meant that) cloth is I believe for corrosion protection. Tuff glide will work as an oil. Militec is also good. CRK Grease seems to be the best but I never tested that.
Ted
  #15
Old 06-16-2003, 02:45 AM
Nathan S's Avatar
Nathan S Nathan S is offline
Registered User
Great thread, great pictures. I agree, this should be a sticky. Maybe some kind mod will help us out.
  #16
Old 06-16-2003, 02:57 AM
PiterM's Avatar
PiterM PiterM is offline
Registered User
That's a great tutorial!
  #17
Old 06-16-2003, 08:52 AM
FivePointOhh's Avatar
FivePointOhh FivePointOhh is offline
Registered User
Excellent job Ted!!! Great tutorial and pix!
Sticky it!
  #18
Old 06-16-2003, 10:41 AM
Geode's Avatar
Geode Geode is offline
Ted - your post is destined to become one of the classics. Thank you for taking the time and effort to very clearly document your techniques.
  #19
Old 06-16-2003, 11:18 PM
Scott Dog's Avatar
Scott Dog Scott Dog is offline
Registered User
Wow! Good job Ted!
  #20
Old 06-17-2003, 09:56 AM
DBH DBH is offline
Registered User
Nice Photos Ted, great job.
Closed Thread
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© Copyright 1998-2010 BladeForums.com. All rights reserved.
BladeForums.com is an adult website with adult discussions.
In accordance with the COPPA, no one under the age of 13 may join BladeForums.com
