BladeForums.com
General | Community | Makers | Manufacturers | Exchange | Archives
Want to Sell Knives? Private Message? Post Polls? Upload Pictures?
Upgrade your forums experience, and help support this site.
Go Back   BladeForums.com > Knife Maker's Forums > General Knife Maker's Discussion > Shop Talk - BladeSmith Questions and Answers
Notices
Shop Talk - BladeSmith Questions and Answers The art of knife making- advice on methods, supplies, and materials
Reply
Thread Tools Display Modes
  #1
Old 01-08-2002, 04:17 PM
Mark Williams's Avatar
Mark Williams Mark Williams is offline
Moderator
Filework made easy......well,.....easier.
I was having trouble getting my spacing right even when marking my blade spine.
So off to the shop.I found some steel rods that were the same diameter as each chain-saw file that I use.I drilled some holes in several pieces of 3/4 x 3/4 x 1 1/2" aluminum. The holes are the same diameter as the file and rod. Press the rod and file into the holes on each end and Presto. You now have evenly spaced cuts much like a checkering tool.You can space the holes differantly for each matched set of file/rod holders. It works great. Just make your first cut, then lay the rod into that cut and so on. You could probably get real fancy with this if you wanted by making the distance between the file and guide rod adjustable with a split block. Hope this is of help to someone.
Mark
__________________
R.I.P. G+
"Come in peace,or leave in pieces"
"You never know when you might need to dag someone." - Bastid
"Another frikin year...whoopity-do."
- Claude Ellis Jessie
  #2
Old 01-08-2002, 05:11 PM
txwoodchip txwoodchip is offline
Registered User
Thumbs up
That's a great idea! Here's another method if you're lazy like me...just draw the pattern on a mailing label, cut it out, and attach it to the spine.
  #3
Old 01-08-2002, 07:44 PM
peter nap's Avatar
peter nap peter nap is offline
Registered User
That's a good idea Mark. I have also found that marking with a pencil and making a notch with a small tri file helps me be precise.
  #4
Old 01-08-2002, 09:20 PM
WinDancer's Avatar
WinDancer WinDancer is offline
Registered User
Another Option....
I bought a pair of shears that cut a nice, even squiggle [sorry about the technical terms I think they are called pinking shears]pattern. I just cut the pattern on paper and then tape it onto the spine and file away.
I start each cut with a very thin file; it is easier to get them even, then follow up with my cobalt spiral bit in the router.
I find it much easier to control tyhe cuts with the cutter fixed and the blade in my hands.
This really throws a lot of needles, and I don't recomend ayone else doing this
Dave
  #5
Old 01-09-2002, 02:28 PM
Moderator
Dave,
As accident prone as I am , I could foresee a trip to the local E.R.
Mark
__________________
R.I.P. G+
  #6
Old 01-09-2002, 04:41 PM
peter nap's Avatar
Registered User
Thanks Dave...a new way to hurt myself. I've used the router to mill aluminum but I hadn't thought about it for filework.
  #7
Old 01-10-2002, 04:54 AM
Harry Jensen Harry Jensen is offline
Registered User
Gee......wonder if anybody's tried using an old key cutting machine for fileworking........naaaaaah......be much too easy!
  #8
Old 01-14-2002, 02:11 PM
sattley sattley is offline
Registered User
Measure and mark where you want you file cuts with a scribe. A very sharp cold chisel will "feel" the scribed line on the corner of the spine. Ding the scribed lines gently with a cold chisel on the corner of the spine. You now have a notch that will hold your 3 square needle file to make the starts for your cuts.
  #9
Old 01-14-2002, 09:33 PM
Eric M Ericson Eric M Ericson is offline
Registered User
the only times i've tried it, was on a hardended blade.
i tilted the table on a 1 in belt sander and used the edge of the belt to cut the patern. It goes quick, a little tricky to control, and realy easy to screw up and go to far....Eric..
I'm going to try files one day, but i'm a tool maker not an artist.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© Copyright 1998-2007 BladeForums.com. All rights reserved.
BladeForums.com is an adult website with adult discussions.
In accordance with the COPPA, no one under the age of 13 may join BladeForums.com
