| Shop Talk - BladeSmith Questions and Answers The art of knife making- advice on methods, supplies, and materials |
Thread Tools | Display Modes |
#1
question about gun-kote
need some advice from some folks that have used it. I'm thinking about picking up a 16-ounce can of this stuff but was wondering about dipping, etc. How did you go about applying it? Did you put it in a more slinder container and dip it? Any tips and tricks?
#2
I believe they have spray cans, and non aerosol, for dipping, painting, or pouring in paint spray guns, or airbrush.
It's not real easy, like spray paint. You can see in the links below. http://www.kgcoatings.com/gunkote.html http://www.kgcoatings.com/gunkote_products.html#1 http://www.kgcoatings.com/application.html Edited to add; It looks like K-Phos is much easier to apply. http://www.kgcoatings.com/kphos.html
__________________
Mike Last edited by Mike Hull; 12-23-2004 at 09:29 AM. |
#3
Quote:
No idea if I'm doing something right (or wrong) - what isn't easy, Mike? I quite like the finished result for some stuff - I did a test blade in O1 to give it a bit of a beating. The best way I've found of reliably scratching the coating is to dig in some heavy clay with the knife, then sheath it without cleaning in a tight-fitting Kydex sheath a number of times... Apart from that (which qualifies as abuse of a knife as far as I'm concerned), it seems pretty reslient. Peter |
#4
This sounds like pretty good stuff for some applications. Anyone have pictures of the various colors?
#5
Er... I only have black. It's sort of a black colour, with a hint of black (and black highlights). Satin finish rather than a gloss, and it is a swine to photograph.
Oh - and regardless of what makes apparent sense, a grit blast with 120 grit does NOT hide 80 grit scratches (which are more-or-less invisible after blasting) after this stuff is put on... I've started going to 220 grit before blasting at 120. Peter |
#6
Quote:
Regards, Greg |
#7
Hey, Michael. I have used Gun-kote several times. I don't know if you can dip it or not, but I use an airbrush to apply mine and it looks very nice. Make sure you beadblast the blade and then warm it to about 100 degrees before applying it. It helps the material stick better.
Here is a link to one I just done: http://www.bladeforums.com/forums/sh...d.php?t=326491 |
#8
How does Gunkote compare to other coatings such as Duracoat and Parkerizing?
Thanks
__________________
#9
I've used GunKote many times on knives and guns.
My current carry .45 Commander is in brushed stainless color GunKote. The part needs to be thoroughly degreased as it will leach out when you preheat the part. I sandblast the blade, gunpart, etc....the degrease with Gunscrubber, acetone, etc then heat the part to about 160F....then apply the Gunkote with an airbrush. The liquid is very thin and doesn't look like it will cover.....but it does nicely. After airbrushing I let the part air dry for about 20 min and then it goes into the oven at 300F for 30-45 min. The finish is very tough....pretty much the same stuff of Reeves knives.....if you want extra tough....parkerize the part first then GUnkote over it. Here is a link to a pic of the pistol: http://www.bladeforums.com/forums/sh...d.php?t=298674 Last edited by Greg Covington; 12-31-2004 at 01:19 AM. |
#10
Great information from all ! The gun kote site has good info also - has anyone used their K-phos ( I assume it's like parkerizing) as an undercoat, and does it help?
Another, possibly dumb question - when you guys say "airbrush" do you mean "hobby type airbrush" or like an HVLP or professional type spray apparatus? Thanks for the info! Bill |
#11
yes good info
I've added the site and this thread to the knife making site. http://www.knivesby.com/knifemaking.html under Suppliers hit over 48,000 times now some body likes it
#12
Quote:
I use a Paasche hobby airbrush and it works fine......you have alot of control with these and can do camo stripes, etc. The airbrush is essential...compared to the aerosol cans. It puts on a thinner coat which seems more resistant to scratching than the thick coats that the spray cans do. I have found Gunkote to be 50-75% tougher than baking lacquers, Alumahyde, etc.... It is good stuff for sure if applied right....and that is pretty easy |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
