| Tech Support, General Q&A, Site Feedback & More Technical Support, Suggestions, Feedback, and Customer Service... |
Thread Tools | Display Modes |
#1
I saw a thread about it earlier but cannot find it!
Cougar can ya link me [this post] to that thread , homie?
__________________
#2
__________________
Contact: esav@bladeforums.com |
#3
Those stalking screenshots you posted showed you using Netscape.
Ain't as L33t as you pretend? At least you got your "homie", ramanonforums.
#4
Are you still allowed to use that "RamanonForums" account?
#5
CF
Your posts here are out of line. No more warnings.
__________________
#6
You should use Firefox- I do, and I have not had a problem, Freeze up, or pop up since I switched. It seems to work faster than IE also.
__________________
#7
Quote:
I would have to agree with you there. I find it much better to deal with. Hope you got it taken care of Labella
#8
A possible clue:
I have observed today in two hang-ups that it seems to aflict longer posts. The same thing happens if one attempts to edit a longer post. When you go to save the changes, IE6 (Under XP) locks up tight.
__________________
Balisongs -- because it don't mean a thing if it ain't got that swing! http://www.balisongcollector.com
#9
I have just completed all outstanding patches and updates for my Windoz XP system and that did not help.
__________________
#10
Quote:
Seems like the longer the post or reply - the more likely it is going to lock-up IE6. Just to show difference I am on Windows Me and IE6 (both updated regularly). Since the majority of the internet world is on IE6 - I would suggest this is a pretty serious BUG. For 3 days now I have still NOT been able to post my response in that thread over at Knife Reviews & Testing. -- Vincent http://UnknownVT2005.cjb.net http://UnknownVT.cjb.net http://UnknownVincent.cjb.net |
#11
I was just able to post over at Knife Reviews & Testing with the message that I had 3 days' worth of failed attempts - I was taken aback by the really FAST response time for posting - just like before all these problems.
I came here to post/ask if this problem had been fixed - and IE locked up on me. The only variation seems like I deleted the QUOTE - whereas the failed post here had a previous QUOTE. Let's see if it makes any difference without the tags.... EDIT: Yep, the QUOTE made the difference this posted really FAST, like there was no problems whereas the posts that LOCK-UP IE seemed to all have been ones with previous QUOTEs -- Vincent http://UnknownVT2005.cjb.net http://UnknownVT.cjb.net http://UnknownVincent.cjb.net Last edited by UnknownVT; 08-02-2005 at 11:31 AM. |
#12
This is a trial post using the QUOTE button -
then deleteing the QUOTE tag. The Preview worked fine and FAST - I think this might be it. For me I think I'll have to avoid having previous QUOTE tags in the message for now......... -- Vincent http://UnknownVT2005.cjb.net http://UnknownVT.cjb.net http://UnknownVincent.cjb.net |
#13
Here are two more datums.
I have observed that there are certain threads where I simply can't make even a two-line reply while making long replies in other threads works fine. I have also observed that this problem tends to set in more as threads get longer and longer.
__________________
#14
Quote:
havent had the problem but the one day. seems to be fine now??- but I tried updating windoze, too!
__________________
#15
* just locked up while trying to post the above for a few seconds!!
__________________
#16
I have been using AD Browser and it has locked up a few times maybe 3
times that is. Normally when I try to submit a reply. I shut down and restart and my post is entered when I log back on though. |
#17
Quote:
__________________
#18
Are you guys using the quick or advanced text box when this is happening?
__________________
Kevin Jon Schlossberg Owner, BladeForums.com Only Sharp Knives are Interesting
#19
Advanced, in my case.
__________________
#20
Quote:
It's normally the QUOTE=username like above that causes the lock-up - most of the times when doing multiple Preview Posts, and then any Edits. I'll just do a Submit Reply withOUT any Preview Posts. If this post is successful - I'll try to return to Edit this post..... -- Vincent http://UnknownVT2005.cjb.net http://UnknownVT.cjb.net http://UnknownVincent.cjb.net |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
