BladeForums.com
Specific | Related | Community | Makers | Manufacturers | Exchange | Archives | Help
Want to Sell Knives? Private Message? Post Polls? Upload Pictures?
Upgrade your forums experience, and help support this site.
Go Back   BladeForums.com > Service & Support > Tech Support, General Q&A, Site Feedback & More
Notices
Tech Support, General Q&A, Site Feedback & More Technical Support, Suggestions, Feedback, and Customer Service...
Reply
Thread Tools Display Modes
  #1
Old 08-02-2005, 01:16 PM
Carl64 Carl64 is offline
Registered User
Post testing
EDIT: This message posted as fast as anything, so it sure ain't quotes. I have never posted pictures and still have issues, so that's not is either.
Original Message:
I didn't see an official test forum, so I am trying some posts with extensive quotes to see if the posting issue is any worse. RUmor was lots of tags were an issue.
Quote:
Originally Posted by Carl64
Quote:
Quote:
Hellertewrtwertwetero Hello Hello Hello Hello Hello Hello Hello Hello Hello Hello
Hello Hello Hello Hetwetwertewrtrewtwertertwello Hello
Hello Hello Hello
Hello Hello Hello
Hello Hello Hello
Hello Hello Hello
Hello Hello Hello
Hello Hello Hello
Hello Hello Hello
Quote:
Hello Hello Hello
fsdfsdfdsfdfs
  #2
Old 08-02-2005, 01:20 PM
Nordic Viking's Avatar
Nordic Viking Nordic Viking is offline
ADHD???? -> You have ?
__________________
  #3
Old 08-02-2005, 04:52 PM
UnknownVT UnknownVT is offline
Registered User
Exclamation
Hey fellow sufferer .....
This is also a Trial - instead of using the default the QUOTE=Carl64 - I changed it to what I think Carl64 used ie: just the QUOTE /QUOTE tags.
I did a Preview and it worked just as Carl said as FAST as anything.....
EDIT - I am going to try the DEFUALT form of "QUOTE=username" in my next post to see if it works and whether I have isolated the problems for me, at least......
Vincent
http://UnknownVT2005.cjb.net/
http://UnknownVT.cjb.net/
http://UnknownVincent.cjb.net/
  #4
Old 08-02-2005, 05:19 PM
Registered User
Exclamation
The QUOTE=username form in this case "QUOTE=Carl64" - seems to work under limited circumstances for me - it seems to Preview once (or twice) fine, than will Lock-up IE on Submit.
Or will Submit fine (without any Previews) - but then will more than likely lock-up IE on any attempt to Edit the post.
If this is successful I will immediately return and Edit this post -
if you do NOT see an edit it means I have failed and IE was Locked-Up......
Vincent
  #5
Old 08-02-2005, 05:33 PM
Registered User
Exclamation
Just to be explicit - I attempted to Edit the above post as I promised TWICE - both times Failed with IE lock-up - even though I did a simple Save Changes withOUT any Preview
Preview worked on this post Multiple times as fast as anything -
so hopefully Submit Post will work too?
EDIT #1 - yes, it worked too as fast as anything - so here's the 1st Edit on which the Preview worked fine too.
EDIT #2 - just to show that multiple edits do not have problems either. Multiple Previews also worked fine on this second Edit.... so Save Changes or Submit should work fine for this second edit too.
EDIT #3, #4 even #5 (to correct typos) - worked too.
In summary - it would appear - at least for me -
The QUOTE=username form - seems to work under limited circumstances for me - it seems to Preview once (or twice) fine, then will Lock-up IE on Submit.
Vincent
  #6
Old 08-02-2005, 05:50 PM
Registered User
I just tried all sorts of edits and previews, and I can't get it to happen now.
  #7
Old 08-02-2005, 05:53 PM
not2sharp's Avatar
not2sharp not2sharp is offline
I had it lock up on my previous post. The post finally went through but it took a while.
n2s
__________________
See my stuff at:
My Stuff
Tagline:
There is no good, no evil, no saints, no demons; There are just ordinary people making ordinary choices.
  #8
Old 08-03-2005, 02:16 PM
Ryan8's Avatar
Ryan8 Ryan8 is offline
Registered User
Friends don't let friends use Internet Explorer. It's 4.7 megs, not a huge download. It's not currently affected by spyware or viruses. It renders web pages significantly faster than IE. Tabbed browsing, better cookie controls, RSS feeds, more secure password manager, tons of free add-ons...
  #9
Old 08-04-2005, 11:41 AM
Registered User
Exclamation
Ryan8 wrote:
I do realize you're trying to be helpful.
BUT the fact of the matter is that BladeForums is posing some difficulties for some users who ARE using IE6 -
this is a PROBLEM for Blade Forums - and pretty serious -
since the majority of the internet population does use IE -
whether we like it or NOT.
I have some very good reasons for being on IE6 - without which would render some of my use the the internet inoperable -
yes, I have installed and used FireFox - but unfortunately it is not compatible with an essential component I use for the net.....and the only Browser that is compatible was IE6.
Vincent
  #10
Old 08-04-2005, 08:54 PM
Ryan8's Avatar
Registered User
Yeah, I know it isn't a perfect, simple answer for that reason.
It's a decent temporary workaround for some, though.
The unfortunate situation is that some people find websites or plugins they need to use that won't work with Firefox. This is rapidly changing however.
As a side note, there may be some problems with the vBulletin code. However, nothing should cause a web browser to freeze. It could be used as a denial-of-service attack. So Microsoft needs to fix something as well.
  #11
Old 08-05-2005, 05:06 PM
Registered User
Exclamation
Ryan8 QUOTE: As a side note, there may be some problems with the vBulletin code. However, nothing should cause a web browser to freeze. It could be used as a denial-of-service attack. So Microsoft needs to fix something as well. UNQUOTE
Like many I do realize that MicroSoft code is far from perfect.
But unfortunatley it is the de-facto standard - even if we don't like it.
Unless there is a very good reason, why do we/BFC have to take it upon ourselves to buck the system, and cause "innocent" BFC members problems?
I mean BladeForums was working just FINE for me for YEARS before the recent update/upgrade -
it is ONLY since the update that the browser lock-up problems have occured. All my internet software is pretty standard and I am not trying to do anything "fancy" -
So is it REALLY MY responsiblity to go tell MicroSoft to change/correct IE6 so I can surf BladeForums without lock-up problems - like before? when I haven't a clue to what exactly is wrong with it, and it ONLY happens on BladeForums since the update (and NO other website that I frequent)?
Vincent
  #12
Old 08-05-2005, 06:08 PM
ronsec's Avatar
ronsec ronsec is offline
Don't Worry - Be Happy!
I have been trying to post in W&C twice now and it hangs up my IE6. Never happened before - what gives?
__________________
Ron
"It ain't easy bein' me!"
  #13
Old 08-07-2005, 01:39 PM
Registered User
Arrow
ronsec wrote - QUOTE: I have been trying to post in W&C twice now and it hangs up my IE6. Never happened before - what gives? UNQUOTE
This is not restricted to any particular section/forum.
I have had IE6 lock-up on me on three attempts to post a reply - simply by keeping the standard default QUOTE=username tag.
I have found that using the QUOTE=username tag seems to cause me problems, especially using multiple Previews or Editting muliple times.
WithOUT the QUOTE tag I seem to be able to do multiple Previews, Post, and Edit multiple times fine and fast.
I thought it might have been having a tag right at the start of the post that cause me problems with locking-up IE6 - but some of my attempts to reply to the post with something typed before the QUOTE=username tag locked-up my IE6.
There are two other threads in this forum that relate to this problem -
Preview and Submit Post Locks up
or
IE locks up BAD when posting!
EDIT #1 & #2 - with multiple Previews - to show that without the QUOTE tag everything is normal and fast.....
Vincent
  #14
Old 08-07-2005, 04:25 PM
Ryan8's Avatar
Registered User
I believe this issue has been reported on other forums running vBulletin. No, it's not your responsibility. I think that if someone here (Spark?) happens to discover precisely what is causing the issue, it should be reported to Microsoft because we shouldn't have browsers locking up.
  #15
Old 08-08-2005, 06:19 PM
Registered User
EDIT: testing
I just tried replying to my original message 3 times, each with the full thing quoted as it was, and it locked up every time. Previously I was unable to get it to happen twice in a row. There is no method to this madness.
  #16
Old 08-09-2005, 04:34 PM
Siga Siga Siga Siga is offline
Registered User
test......
  #17
Old 08-09-2005, 05:07 PM
not2sharp's Avatar
I don't know about Microsoft; but, I suspect the problem has something to do with font sets. I have had post windows displaying unfamiliar fonts and other post windows displaying no fonts at all. I have also had it freeze solid when doing a post preview, even though posting w/o the preview seems to work.
n2s
__________________
See my stuff at:
My Stuff
Tagline:
  #18
Old 08-11-2005, 12:42 AM
Registered User
cough cough
  #19
Old 08-11-2005, 06:40 PM
Spark's Avatar
Spark Spark is offline
HPIC
Ok, a bunch of fonts have been removed out of the CSS in an effort to slim it down. We'll see if that works.
__________________
Kevin Jon Schlossberg
Owner, BladeForums.com
Only Sharp Knives are Interesting
  #20
Old 08-12-2005, 10:07 AM
Registered User
Arrow
Quote:
Trial posting with QUOTE=user tag - with multiple Previews
Preview #1, #2, #3
Preview seems to work fine -
hmmmmm............ seemed to have a bit of a delay like the browser was about to lock up on the last Preview #4 & #5 ....... but they eventually worked.
Will return to do Multiple Edits if this posting is successful.
Vincent
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© Copyright 1998-2010 BladeForums.com. All rights reserved.
BladeForums.com is an adult website with adult discussions.
In accordance with the COPPA, no one under the age of 13 may join BladeForums.com
