1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
1055 steel vs 1095 steel! Info please.
Discussion in 'General Knife Discussion' started by xX_Blade_Xx, Aug 26, 2013.
  1. xX_Blade_Xx
    xX_Blade_Xx
    132
    Aug 2, 2013
    Just bought a Cold Steel Kukri and am very impressed. The handle is just fantastic and i have always wanted a kukri. I know next to nothing about the steel other than the fact that its good at taking a beating. The machete wasn't sharpened of course but i am sharpening it by hand. What should i expect from this steel? Seems real tough so far. I am familiar with 1095 carbon if it would be easier to compare the two then feel free. i enjoy learning. Thank you in advance! :)
  2. Kwon Kwang
    Kwon Kwang
    Jul 7, 2013
    Looks like what you got was the kukri machete, which is a machete shaped like their old discontinued ATC Kukri.
    1055 is far better than 1095 for a machete, because it's softer and so can take more of a beating, though it certainly won't hold an edge like 1095.
  3. knarfeng
    knarfeng senex morosus moderator Staff Member Super Mod Moderator
    Jul 30, 2006
    1055 is an appropriate steel for blades which are expected to suffer impacts during normal use. Throwing knives, machetes, and bayonets are frequently made from 1055. Easy to sharpen, doesn't typically hold an edge all that well.
  4. Camber
    Camber Gold Member Gold Member
    Jul 13, 2011
    If you do not have much success sharpening it at first, don't get discouraged is all I can add. The way Cold Steel puts the edge on usually burns the edge (not hard to do on that steel) and so you often have to remove 1/32 to 1/16 of an inch from the edge before it begins to stabilize. Til then it may not hold an edge for very long or the edge may get duller if you try to go to a high grit polish.
    After you get through that steel though, it should hold a great edge for chopping and other rough work, probably better than 1095 as it is better for withstanding the impacts that cause a chopper to dull.
Share This Page
