1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
410 stainless steal? will it rust?
Discussion in 'Maintenance, Tinkering & Embellishment' started by Legenda, Jan 15, 2012.
  1. Legenda
    Legenda
    349
    Mar 2, 2011
    I got a little water down in the 410 stainless steel handle of my kershaw scallion. couldnt get it apart cuz the back of the pivot spins with the screw, so i sprayed a bunch of gun oil down there, will it rust?
  2. richard j
    richard j
    Apr 1, 2007
    i doubt it will rust. to keep the pivot pin from spinning, press it down on a piece of leather while unscrewing it and it should come loose.
  3. Legenda
    Legenda
    349
    Mar 2, 2011
    I allready tried. Pressed down as hard as I could. Any suggestions?
  4. knarfeng
    knarfeng senex morosus moderator Staff Member Super Mod Moderator
    Jul 30, 2006
    You can get rid of water by rinsing with acetone, then oiling.
    However, 410 stainless is highly rust resistant (that's why they use it) and I wouldn't worry about it. I especially would not disassemble the knife. Likely to cause more harm than good.
  5. Don't worry about the handle rusting, especially if it's just fresh water (saltwater might be a concern). 410 stainless is very rust-resistant. If any water remains inside, it can be flushed out with WD-40 or isopropyl alcohol. Personally, I'd avoid using acetone. If there are any plastic or nylon components in the knife (bushings, maybe), it might damage them.
    I agree, there's no need to take the knife apart for this.
  6. xmtgx
    xmtgx
    549
    May 11, 2007
    No need to take the knife apart, but you can open the blade and bend it as to put pressure on to the pivot, It should let you unscrew it without the pivot spinning.
  7. Noctis3880
    Noctis3880 Gold Member Gold Member
    Jul 22, 2009
    Or press it on the underside of your mouse pad for traction:thumbup:.
    I would agree with the others and recommend that you don't disassemble the knife, especially Speed Safe openers, unless absolutely necessary. WD-40 in the pivot should flush the water right out.
  8. Legenda
    Legenda
    349
    Mar 2, 2011
    thanks guys. i allready got it apart. taped a small piece of rubber to tha back of the pivot as tight as possible, then to top that off i pushed down on it with my finger as hard as i could, and was able to get it apart.
Share This Page
