- Oct 16, 1998
AFCK AXIS
With this review you will have the chance to improve your french with our first lesson of french applicated to "coutellerie".
Hummmmm let's look at it:
0.125 inches of blade thickness
compared to the 0'115 used on recent folders since the BM910....,
My Gad, this is a very serious business:
you got a design which has been acclaim since 1995 (Mark Mcwillis and Chris Carracy's colloboration)
You got n ergonomy which is legendary especially for reverse grip.
You got one of the strongest lock: the Axis Lock
You got D2 an air hardenned Alloy which has been used with great reliability by legendary knifemakers.
The Advanced French Cooking Knife is born again!
SO let's ask Fred Perrin what he has made with it:
"Voila ce que je peut dire sur afck
depuis quelque temps j'utilise un afck axis lock et lame en d2 grace a
l'aimabilité de Benchmade."
First Fred would like to thank Benchmade to let us the opportunity to try and test their AFCK with D2 blade.
"J'ai depuis longtemps toujours eu un faible pour
ce modele qui etait avec un linner a l'epoque,a la sortie de l'axis l'idée
de voir ce systeme sur un afck me semblait ideal.c'est maintenant le cas
voyons le resultat."
Fred alawys love the AFCK even with a liner lock. WHen he first test the axis lock he always wished to have it adapted on the AFCK.
"la prise en mai reste toujours aussi bonne le poids est
correct pas trop lourd,la lame se manipule facilement grace ou trou placer
dessus le fini noir a du bon pour les usage tactique et assure une
protection anti corrosion en plus,la lame combo permet de repondre a tous
les usages."
The ergonomy is as good as before. The weight is OK not to heavy. The blade is easy to unfold thanks to the oval hole and he likes the BT2 for its military use and the rustproof protection. Also he like the combo blade for its extreme polyvalence.
"j'utilise ce modele pour divers travaux telle que couper des
cordes des sangles,du carton,j'ai aussi utiliser ce modele lors de stages de
cqc "
Fred uses the AFCK for a lot of task : cutting ropes, straps, cardborad, but also he uses it in his CQC workshops.
"...ou je démontre les effets des coupes sur des tetes de cochon tand en
coupe qu'en pic ce permet de se faire une id de la solidité du lock et de la
lame mais aussi la prise en main,lors de ces stages..."
He does demo with Pig's Heads and use his knife in thrust and slashes to show the damage of a blade attack. So he has evaluate how well the axis lock is safe but also how the grip is safe.
"je démotre aussi des pic
sur des gillet de protection afin de sensibiliser les professionels au
limite du materiel j'utilise aussi ce modele pour de demos de jet a courte
distance -de deux metres ."
To show the power of live blades to professionals he also stabbed his AFCK into kevlar jackets. He does to show them the limits of their equipements. Also he uses his afck as a throwing knife at a 2 meters range.
"lors de tous ces essais je n'ai eut qu'a me
satisfaire de ce couteau la lame garde bien la coupe et a un affutage razoir
les serrations sont efficace bien que j'aime les plain edge j'apprécie ces
serrations sur des utilitaires a vocation professionel car la coupe de
matériaux modernes cordes de rappel,bretelles de sac ou brellage peuvent
etrenecésaire lors d'action de rescue ou de training est la la qualité de
coupe sera d'un grand secourde plus lors de franchissement ou de trvaux dans
l'eau les serrations ont un réel pouvoir de coupe ."
After all of this, Fred AFCK kept its razor edge. The serrations are useful especially for soldiers and profesionnal in security who need to cut fast into the fiberous materials, especially for a rescue mission.
Also the serration perfectly works underwater.
"ce modele permet aussi
des ouvertures trés pratique comme la babyfoot qui ouvre le couteau d'un
coup de poignet en rotation cette technique me permet des ouverture trés
courtes(vase clos) mais aussi avec des gants qui sont parfois genant "
Fred open the AFCK with a quick rotation of his wrist. Inertial openings are easy and really practical when you wear gloves.
Also he use this technique in very close range CQC techniques.
"pour
prendre appui sur le trou.la présence d'un trou passe dragonne sur le manche
permet de placer ma dragonne que je réalise avec de l'élastique sur les
folder ce qui me permet de passer le poignet dedans trés vite est garanti ma
sécurité notament lors des actions aquatiques (franchissement de rivierre)
ou l'usage d'un couteau sera dans une situation d'urgense la lîdeal sera
d'avoir le couteau sous la main et nom pas dans la poche."
Fred also use an elastic lanyard on his AFCK , because he can put his hands through with more ease. He needed this security while he has used its AFCK crossing a river.
"jepense que ce
modele sera unchoix sérieux pour un pliant a usage professionel ou pour des
activiter sportives la qualité sera au rendez vous."
Fred thinks the AFCK is a top choice for professional soldiers, policemen and sportsmen. The quality is top notch.
You see french is not difficult to spek especially about knives and edges.
So say "Fromage"...
cheers,
JM
les usages."
cqc "
"pour
"jepense que ce
So say "Fromage"...
cheers,
JM
