- Feb 1, 2012
I don't see a lot of difference in that image. Is the long soak on the right?
Nice experiment! I guess the next test is to determine of that much oil will cure, or allow the wedge to remain oiled and start backing out.
Thin coats are used because thick coats interfere with propercuring.
Great information "mete">> and believe me I'm in no way trying to derail this most interesting thread. But I do have one question in regards to linseed oil. A few years back I got a video and information packet from the US Forest Service that was done by a guy name Bernie Weisgerber.
What was edited from "an ax to grind" is that the pure raw linseed oil is cut 50/50 (or so, depending on how dry the haft is) with pure gum terpentine. This helps with the penetration and drying time of raw linseed oil. The reason not to use BLO is the personal safety issues. I follow this with some softened bees wax.
This is an excellent thread.
I've got a haft going right now with RealMilkPaint's 50/50 blend of pure tung oil mixed with citrus solvent. My first go round with this product was a disappointment - very long drying time. But this time I've been giving it a shake before each use. It's drying in 24 hours now. The 3rd coat went on tonight and I'm planning on using at least 6 coats. I'll let you all know how it goes.
Square_peg, I was wondering how this went for you as I am considering going this route. Also, I noticed the following line from their website. For dense hardwood, a 2 part Citrus Solvent to 1 part Pure Tung oil is recommended. In your opinion, is this necessary or just the 50/50 blend? Thanks!
You can also take blo put it in a jar,cover with cheese cloth and in a few months you will have the equivalent of traditional blo to. Just basically linseed oil with more of the moisture evaporated out.
From what I researched it isbhighly recommended to use "raw lineseedoil" instead of "boiled lineseedoil" (which contains chemicals to dry faster).
The downside is that raw lineseedoil will need way longer to try but is healthier and better for the wood.
I also thought about mixing raw lineseedoil with beeswax?
This could make a nice finish coat, but as a treatment it would have to be dangerously/burning hot to penetrate properly. There are better ways.
I put a hammer in the oven once at the "WARM" temp to heat it up prior to hitting it with beeswax. It was a bit too hot to comfortably hold and the end of the handle checked a little from the heat. I think that the best way is to choose your favorite penetrating oil combo and if finishing with beeswax just do it the old fashioned way and rub it in. It's just for the surface mostly anyway.
