- Jun 9, 2011
yep. agree completely.All depends which furnace and evap coil you have.
Your choices are limited if you aren't changing out the furnace & coil.
Coil & outdoor unit MUST be compatible.
Joe
code here is ahri match, or mechanical engineer spec'ed and certified/approved...which youd never get done by any real engineer..... which means no outside only unless coil matches and i doubt it would.
replace the evap coil and outdoor at the minimum.....instead of replacing your furnace, unless you got a straight cool w/fan coil with electric heat....then use that money to buy a few knives.
you refrigerant guys dont give up or wimp out. no only oem part swapping nonsense..... bypass until runs again. sharp knives come in handy as youve shown.
