1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
Chisel Knife
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by mocaba, Oct 14, 2012.
  1. mocaba
    mocaba
    87
    Oct 13, 2012
    Okay, I am a noob just starting out knife making, but I have a really good idea for a knife, and before I attempt it wanted to make a prototype out of a chisel. The reason I want to do this is because it has something to do with a chisel so if I could just use one and modify it, could become a lot easier to see if the knife idea would actually work for real use.
  2. Mikael W
    Mikael W Platinum Member Platinum Member
    Apr 21, 2007
    Hello mocaba!
    Chisel knives are availible overhere in our hardware stores and at fairly the same quotes as chisels.
    I too have found it fun to experiment with chiselknives, in order to do conventional knives from a strict working tool.
    This is a WIP from a Bacho #2448 chiselknife
    Last pic is together with a Bacho #2449
    The #2448 and #2449 are the same except for the tip.
    Really ugly thingy's, but 4mm thick and 100mm bladelenght.
    Hardness is kept at the lower side to maximize toughness and ease of sharpening.
    My knife isn't finished yet, but it's assembled with a nut and can be used as is to test how it will work.
    Regards
    Mikael
  3. FortyTwoBlades
    FortyTwoBlades Baryonyx walkeri Dealer / Materials Provider
    Mar 8, 2008
    Mora makes a chisel knife, too. Doesn't really sound like the OP is asking a question though. I'll admit I'm a little confused. :confused:
  4. Shorttime
    Shorttime
    Oct 16, 2011
    Uh? Graham Razel?
    Tops Pry knife?
    I've drawn some chisel-point knives, but never put steel to wheel, as it were.
  5. Mikael W
    Apr 21, 2007
    I know, I don't believe the OP has the same intentions as I have, but I think a chiselblade is an easy way to get a blade for custom work.
    Regards
    Mikael
  6. CARRERA50
    CARRERA50
    Dec 20, 2008
    Seems to me Graham has covered all the bases on this one.
  7. Indianbladenoob
    Indianbladenoob
    598
    Feb 8, 2012
    I do believe the OP wants to modify a chisel into a knife.
  8. mocaba
    mocaba
    87
    Oct 13, 2012
    sry if I wasn't to clear in the post, I have an Idea its a kind of multi-tool. On one side would be a saw on the other a cleaver kinda blade. the tip would be a chisel and the faces would be wood files. And this would be a widdling or bush-craft knife of sorts. I was mainly just asking if you could make a decent knife out of a already made chisel but they answered that so the question is kinda done i guess, so I'll try my idea out and see how it works and then post it on here.
  9. Stacy E. Apelt - Bladesmith
    Stacy E. Apelt - Bladesmith ilmarinen - MODERATOR Moderator Knifemaker / Craftsman / Service Provider
    Aug 20, 2004
    I'll offer some simple advice.
    A tool that will do everything will probably do nothing well.
    The skills to make complicated things come from learning to do simple things.
    Learn to make things roll well ...... Then start re-inventing the wheel.
    Take your time. Rome wasn't built in a day, and a knife isn't built in one either.
    Use full text typing, and run spell check. Text message wording and misspelled words are to be avoided on a forum like Shop Talk.
    IMHO, BTW, etc. are OK, but idk, sry and such are best sent to your school buddies.
    Read this sticky about three times, and make a simple drop point hunter. You will then be well on your way.
    http://www.bladeforums.com/forums/showthread.php/694673-How-to-instructions-for-making-a-knife
Share This Page
