- Feb 7, 2013
I normally post over in the tomahawk section but I'm also quite a fan of Kukris as well. If there is a better place for this post regarding kukris, please have this moved. At any rate.......I own several HI kuk's as well as a few productions brands as well. It seems there is a huge following of the Cold Steel Gurka SK-5. I do not own this model but I understand it is a very good "production" kukri. However, of all the production model kukris, it seems the Ontario Kukri would fair just as we'll if not better than the SK-5. Basically same weight, length and thickness. The SK-5 may weight an ounce or two more, but the Ontario has a more pronounced sweep in the forward blade. Ontario uses 1095, which is an incredible steel with a good heat treatment. I'm sure the SK-5 is a great performer but it seems the Ontario would cut/chop at least as well, if not better with that deep sweeping belly. I just don't seem to see too much out there about the Ontario where the SK-5 is getting all the attention.
Do any of you have both blades and if so, which one do you feel cuts/chops the best? Thank you.
