1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
Explosive Cyanoacrylate?
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by Kevin Cross, Jul 21, 2012.
  1. Kevin Cross
    Kevin Cross KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    791
    Sep 13, 2006
    So I have been out of the shop for about five days because one of our bulldogs ran across the yard and took out my wife's leg with a beautiful chop block. Now she has this big brace and crutches and they are saying definately MCL and maybe ACL too. So I have been playing nurse.
    Anyway, I got down in the basement today and went to get to work. First I thought I would clean up the work bench a bit. I grabbed a can of danish oil to put it back in the cabinet over the work bench and it did not move. Neither did the bottle of etchant next to it or the level on the bench top. I tried to open the cabinet and it was stuck shut too. What the heck??? Used a hammer and screwdriver to pry the cabinet door open and moore mess. At the back of the cabinet I had had a new 8 oz bottle of thin cyanoacrylate. Note the past tense. There was about a half in split in the bottle right at the bottom where it has burst and dumped the entire bottle in the cabinet and down over the workbench!
    I spent almost an hour chipping, prying cracking and breaking things loose. I was able to save most things but I really hope that my granite slab was positioned just where I wanted it cause it is going to be there for the duration!
    The good part was this definately put me in a really good mood to grind up some steel so the rest of the afternoon went pretty well.
    So how was your Saturday? Anything blow up on you?
  2. tiguy7
    tiguy7 Gold Member Gold Member
    Jun 25, 2008
    I think cyanoacrylate adhesives do not resist water well. Try covering your problem areas with wet towels. I glued two fingers together once. I held them under running water for 20 minutes, and they came apart. Immersion might work even better.
  3. Basher313
    Basher313 Gold Member Gold Member
    434
    Jun 4, 2012
    Your thread title is awfully misleading, LOL.
    Acetone is the best solvent for removing CA. As an occasional balsa model aircraft builder (been a while, sadly), I've glued my fingers to a fuselage or wing many a time. Get some pure acetone, or if you're in a pinch, some nail remover with acetone. It may take a while to dissolve it all, but it will likely come up.
    Tiguy, CA is actually cured by the moisture in the air. Your fingers likely came apart as a result of them shriveling up under the water, etc.
    Also, be mindful if you use CA near cotton products. Do NOT wear cotton gloves while handling CA! The two materials produce an exothermic reaction (ie., they release heat, sometimes enough for spontaneous combustion) when combined! You can use some on a little cotton thread to bind wire to wood dowels (for making small building tools or pushrods in model aircraft), but that's about it.
    Good luck!
  4. 12345678910
    12345678910
    Jul 13, 2009
    Explosions no, how do incendiaries count? I set myself on fire today doing a bit of welding.
  5. Mudbug007
    Mudbug007
    Nov 29, 2010
    Got a Woodcraft store nearby? Get some debonder and it'll come right up. If not, you can order it from Jantz or just about any other place that sells adhesives.
  6. Kevin Cross
    791
    Sep 13, 2006
    Thank you all, Looks like I'm off to the store today to get some debonder.
    Kevin
  7. jawilder
    jawilder
    Jun 27, 2006
    My question is not how to clean it, but why did it happen in the first place? And how can this sort of thing be avoided in the future?
  8. 12345678910
    12345678910
    Jul 13, 2009
    I store CA glue in a glass jar in the fridge or freezer.
    It seems to keep longer and also keeps it contained.
  9. mete
    mete Gold Member Gold Member
    Jun 10, 2003
    "Cures by moisture in the air " ? I thought it cured by absence of air ?
    Checked -you're right .I wonder why they always said never remove the air from the container ?
  10. Bill DeShivs
    Bill DeShivs KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Jun 6, 2000
    If it was unopened and got hot and expanded, it would split the bottle.
  11. tiguy7
    Jun 25, 2008
    The recommendation to run water on the affected area came from the label on the tube of cyanoacrylate. I wouldn't advise anyone to glue a boat together with that stuff.
  12. stevomiller
    stevomiller
    May 4, 2001
    Yes, gents, store CA in the fridge. In the medical device industry we store all our reserve stock in refrigerators to insure that they are effective through their expiration date. Mete, I am thinking that maybe you have used Loctite CA and threadlockers in the past. The LocTite threadlocker is anaerobic and cures by reaction with 'active' metals.
    As far as the bottle exploding/cracking, I'm not sure. I have handled literally hundreds or thousands of bottles and haven't seen this happen. Was it unusually hot in the basement? Did you possibly get other chemicals onto the bottle?
  13. skilldust
    skilldust
    278
    Mar 13, 2007
    The taxidermist that mounted my last rack opened the frig door to get glue , and I said da%$ what some super glue. He said he buys it by the gross box, keeps it in the frig and it will last over a year. Jerry
  14. Hankins
    Hankins
    Dec 7, 2008
    If you follow forensics they use a CA cloud to bring up hidden Prints... IE: It gasses off when heated and Boom exploding bottle. I store mine laying sideways to keep the air infiltration to a min.
Share This Page
