1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
Forge Burner plans? Need some
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by Bruce Bump, Jan 13, 2010.
  1. Bruce Bump
    Bruce Bump KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Dec 2, 1999
    I'm going to teach a 2 hour college class on knife forging and want to make a burner for Show and Tell. Its not a hands on demonstration but more of an informational for beginners as a hobby. I would like both the venturi style and the forced air type. Anybody have a favorite tutorial on the subject? This could help many people here.
  2. 12345678910
    12345678910
    Jul 13, 2009
    Indian George for forced air (you have to click "ignore the warning" to get there
    http://www.indiangeorgesknives.com/building_a_forge.html
    and Stacy's hi low controls - JT and Nathan B-silver Pilate? have had some good posts
    Ron Reil and this text for Venturi
    Therd are lots of designs
    http://ronreil.abana.org/design1.shtml
    Gas Burners for forges Furnaces and Kilns-Michael Porter.pdf
    http://www.amazon.com/Gas-Burners-Forges-Furnaces-Kilns/dp/1879535203
    Preview it here
    http://rapidshare.com/files/334511615/Gas_Burners_for_forges_Furnaces_and_Kilns-Michael_Porter.pdf
    plus some links
    http://home.flash.net/~dwwilson/forge/plan1.pdf
    http://home.flash.net/~dwwilson/forge/plan2.pdf
    http://www.zoellerforge.com/simplegasforge.html
    http://www.holisticforgeworks.com/gallery/foundry/img/forge_plans.gif
  3. Bruce Bump
    Dec 2, 1999
    A couple good ones there. The Don Fogg for sure. Anybody have more? Imagine that I was a newbie and wanted to build a small vertical forge. How do it do it?
  4. cdent
    cdent
    305
    Aug 28, 2005
    Hi Bruce,
    Not really a tutorial, but you might try the modified sidearm burner at zoellerforge.com. There're links to drawings and faq's that are helpful.
    There are also some basic forge construction tutorials at that site.
    Take care professor:D, get those kids on the right track, Craig
    edit for being a knucklehead and missing the links mentioned above
  5. Will Leavitt
    Will Leavitt
    Jul 28, 2006
    You going to teach them about cut and shoots? :p
    I'd love to be there for this class.
  6. Rusty McDonald
    Rusty McDonald
    Mar 28, 2007
  7. Bruce Bump
    Dec 2, 1999
    That is about what I was looking for. Myself use a mankel but need a link that the new guy could build a working forge, afforable and easy to follow instructions. This one is all of that. Thanks Rusty. :thumbup:
  8. nc_cooter
    nc_cooter
    574
    Sep 26, 2004
    Bruce, the modified sidearm burner shown in that tutorial is an excellent burner. If properly tuned, it will operate from 2# to 30# input pressure.
  9. efleming
    efleming
    679
    Jun 6, 2007
    Bruce, I built my very first forge using this tutorial. The side arm burner is great. Very efficent and can hit welding heat easily with properly designed forge body. It's a great place to start but some day they will most likely want to move on to a forced air burner.
  10. Bruce Bump
    Dec 2, 1999
    Do You have any forced air burner designs?
  11. Dixieblade57
    Dixieblade57
    Jun 20, 2007
    I always like to help a newb, "some helped me out and some still are"! Here is my list.
    http://ronreil.abana.org/design2.shtml
    http://www.arscives.com/bladesign/forge.tutorial.htm
    This next link came from fredlyfx.com and had been posted on this site. It is the design that mine was fabricated from. It has had burner angle modifications, courtesy of Ed Caffrey to create a vortex. The other modifications are of my own design.
    Click thumbnails for larger view:
    [​IMG]
    [​IMG]
    Part1
    http://fredlyfx.com/large propane.htm
    Part2
    http://fredlyfx.com/progress.htm
    http://forgegallery.elliscustomknifeworks.com/
    http://zoellerforge.com/
    Site for parts:
    http://www.rayrogers.com/blower.htm
    http://www.ccallis.com/black_iron_fittings.htm
    http://www.cornerhardware.com/index...page=2&zenid=a322a34851d7fbdaf37b41fc4b9dbf6a
    http://www.blacksmithsdepot.com/Tem...ducts/Forges_and_Parts/blowers/164_CFM_Blower
  12. galadduin
    galadduin
    Dec 25, 2004
  13. Bruce Bump
    Dec 2, 1999
    Do you any dimentions and orifice size etc? Looks nice. Is this yours?
  14. DAMNENG
    DAMNENG
    408
    Dec 17, 2005
    Bruce
    I could not figure out how to post the design and I don't have a website, so I emailed a design for a hybred burner design. Feel free to share it if you wish.
    Jim Arbuckle
  15. efleming
    efleming
    679
    Jun 6, 2007
    Yes. Tall forge with a false bottom. Fully temperature controlled by PID. Holds +- 2 degrees of setting. Temp range is ~1200F to 2500F. Doubles as a salt pot. Remove false bottom to put in sword length salt pot. Bottom burner is used only when full length salt pot is in operation.
    Burner is 14" of 2" black pipe starting at the 75CFM blower then reduced to 1" just after elbow. This config allows for good air/gas mixing. There is also a 1" pipe connector at the end of the 1" pipe as it enters the forge. The tip is kept about 1" back inside the 2" thick kawoal liner to protect it from melting. BTW, this is set up with natural gas running at residential pressure ~.25 PSI (yes 1/4 PSI). The orifice size going into the burner tube is 3/8". Ball valves for adjusting gas flow are also 3/8" as is the smallest orifice size anywere in line. Using NG is all about volume rather than pressure. Nice thing is you are billed on levels of usage. My gas bill does not change if I run this for 32 hours in one month (I'm a weekend maker). What that means is I run my forge for no gas cost and never have to fill tanks. :)
    You can see it at this link --> http://www.flemingknives.com/shoptour.htm
    Just click on the picture of the forge to see detailed views of the burner and control arrangement.
    Hope this helps...
    Eric
  16. Toxey
    Toxey
    112
    Oct 11, 2005
  17. Bruce Bump
    Dec 2, 1999
    Hi Eric,
    Thanks for the tour! You have some nice equipment in there. I like your forge allot. Its not for the newbie though. :eek:
  18. Bruce Bump
    Dec 2, 1999
    That really is easy to make. It looks like a great burner for a new maker or a small vertical. Thanks Man!
  19. amcardon
    amcardon
    919
    Jun 29, 2009
    LOL! Never thought I'd hear Bruce called a newb... :D
  20. Bruce Bump
    Dec 2, 1999
    If ya ask a "newb" question, ya get called a "newb" :D
Share This Page
