Recently I was fortunate enough to purchase one of the limited edition Sub-Saharan 10XMHC-DB (DB for double bevel, the ones available now are "SB" single bevel IE chisel grind). I absolutely loved the design and had to have one; now that I have it I love it even more.
First, let me say the fit and finish isn't perfection. BUT as far as working, actually doing the job and being tough as nails, its 200%.
The handle is G10, with a nice finger groove and good texturing. Its not very coarse, having used it with and without gloves, but I never felt it was insecure. The "Death to Al Qaeda" is a Grayman signature and something I think sets these knives apart: they're all business.
At .25inches thick of 1095, and 17inches overall it is absolutely massive and relatively heavy. The weight is one of those things that's a natural trade off, its tougher and more bombproof, but you have to hump the extra weight.
I have a nice wood pile and picked out a relatively rectangular piece of tough wood to test.
I used relatively little force, no huge swings. Basically it was a bit more than a wrist snap, a bit less than a full on chop.
The Becker BK9, at half the thickness was expected to do well. But it appears the loss in weight and different design makes it more suited for batoning than straight chopping.
My CS Vietnam Tomahawk didn't cut as deeply either.
These stabs were performed with the BK9 and the Sub-Saharan. The top and bottom belong to the Grayman and the center to the Becker. As you can clearly see, the Sub-Saharan is going to leave a much wider wound channel in all directions.
The sheath is MOLLE compatible and has a kydex liner, it holds it knife securely with very little movement which impressed me greatly as it holds it in either orientation. The handle strap is reversible, a nice touch.
The lanyard hole for the nylon out lines up with the drain holes of the kydex liner, the 550 cord is what keeps them secured in all situations. A pretty simple system that does a good job and allows one to easily modify or make a new kydex sheath that's compatible with the nylon by merely drilling holes in the right spot.
Bottom line, I really love this knife!
Grayman will always have my endorsement and I always will turn to this one for the tough jobs.
http://graymanknives.com/subs.html
