1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
Jimping by machine, need bit advice
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by MKaiser, Nov 10, 2009.
  1. MKaiser
    MKaiser
    48
    Nov 7, 2007
    I just completed a small run of knives and I'm trying to find a precise way to do the jimping as I don't really trust my hand with a file, not to mention it would be a ton of hand filing. I'm doing four grooves on the back of the blade where your thumb would go and I need precise depth and spacing. I was going to try doing this with my drill press with some type of 1/8" cutting/abrasive bit, a fence and an 1/8" drill bit embedded in the fence for indexing. But what type of bit should I use for cutting the jimping? Any advice? I've seen some Dermel bits that might work, but if anyone has any suggestions it would be much appreciated.
  2. White Rabbit
    White Rabbit
    155
    Jul 23, 2009
    you could use a metal cutting bandsaw and touch it up with a needle file. or depending on your drill press and if you have a good vise for it you could just try drilling notches on the spine a little bit more than half a bit width wide.
    Personally, I still think filing by hand is easier, and you could probably work up a rig pretty easily that would make more precise cuts.
  3. Mark Redmon
    Mark Redmon
    451
    Nov 7, 2007
  4. MKaiser
    MKaiser
    48
    Nov 7, 2007
    I've thought about making a jig with a file and a brass rod mounted side by side, then using the brass rod as a guide after making the first cut. This is probably the cheapest way to go.
    The checkering files look like a good idea too, I'll have to look into that.
    Thanks.
  5. White Rabbit
    White Rabbit
    155
    Jul 23, 2009
    What I'd probably do for a jig is clamp the knife by the tang in a vise so the blade is sticking up. Then take a rectangular needle file and sand the teeth off on the wide sides so there are only teeth on the end. Then just lay the wide side on the top of the vise so it lays flat and next to the spine where you want the jimping. Then just start filing away and move the knife up or down when you want to change spots.
  6. Nathan the Machinist
    Nathan the Machinist KnifeMaker / Machinist / Evil Genius Moderator Knifemaker / Craftsman / Service Provider
    Feb 13, 2007
    This would be done in industry with crush grinding. You could do something similar by dressing a bench grinder stone with some grooves, leaving high spots in the profile, then grind your design into the spine in one wack.
  7. Chris Meyer
    Chris Meyer Basic Member Basic Member
    Aug 15, 2005
    I too would go with the checkering files. They cut quickly and give nice parallel lines. You select the file by the number of lines per inch you want. By the way, MidwayUSA sells the files cheaper. I don't know if they are the same brand.
  8. Mace
    Mace
    Apr 8, 2003
    I have never heard the term "jimping" pertaining to knives.(Actually I've never heard the term jimping referring to anything) Is this a machining term, or is this a knife term?
    Just curious.
    Mace
  9. Nathan the Machinist
    Feb 13, 2007
    Hey Mace,
    I have only ever heard it used in reference to a knife. It ain't a machining term. It is the cuts or ridges on the spine of a knife to provide traction for your thumb.
  10. sunshadow
    sunshadow
    Oct 2, 2006
    My grandfather used to call any filework on the spine of a knife "jimping"
    -Page
  11. Fred.Rowe
    Fred.Rowe Dealer / Materials Provider Dealer / Materials Provider
    May 2, 2004
    Jimping; I have a new word to add to my vocabulary.
    At first look I thought it was a misspell.
    Fred
  12. Edro20
    Edro20
    984
    Feb 5, 2008
    I first heard the word "jimping" on a YouTube video review of a Chris Reeve knife. I didn't know if this was a "real" knife term or not. Either way I know what the OP is talking about now.
  13. jawilder
    jawilder
    Jun 27, 2006
    I have heard that you can take a metal cutting circular saw blade and mount it on your bench grinder. If you get several blades and separate them with spacers you should be able to grind all of your slots at once and evenly.
    I have not tried it tho.
  14. Chris Meyer
    Aug 15, 2005
    Man, you guys have got to get up to speed on your straight razor lingo. Jimps (or jimping) is what the groves on tang are called. They look good and help give you a better grip.
    These are factory jimps on a new Dovo razor.
    [​IMG]
    And these are some I added to an old Wade & Butcher with a checkering file.
    [​IMG]
    [​IMG]
Share This Page
