If you have a 3 or 4' straight edge, place it along the drive wheel and the grinding wheel and see if they are perfectly aligned. I would guess either the drive wheel is out of alignment or it is somehow loose on the shaft or the same of the grinding wheel. They should be square to each other and the motor shaft and should not wobble in any way.
I don't have a KMG but my grinder will allow me to change belts with very little or no adjustment.
Hope you get it figured out. It's so frustrating when you have to fix the machine before you can use it.
Everything is tight
It might be a quarter degree off in alignment, or less.
