- Jan 21, 2012
can table top milling machines do the job well or should i look at finding a good old knee mill basicaly i need it for slotting gaurds tapering full tang handles 440 c is the steel i will use most
bench top will do just fine for that.....
Metalmole, how would you (personally) use a benchtop mill for tapering full tang knives? I've never figured out how to do it better than on my grinder...
Thanks David,
Was that with a face mill?
I have a setup for face milling stock (with a magnetic chuck), but found it caused stress bending in the thin stuff I was hoping to do it on.
sherline mini mills pop up on ebay frequently.
It's just double... If it's 2 degrees on one side, then you fixture off of that newly cut surface it would be 4 degrees.If you have a big enough mill its not hard....ive tapered tangs on my bridgeport. I did the math and just figured out how much i needed to raise the tang to get the right angle then used a tilting table attachment to hold the blade. The harder part was doing the math over so that when i flipped it over the angle got re-adjusted correctly.
Probably not worth the effort but its certainly do-able with a fullsize mill. I hogged 1/8" of steel at a time.
