1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
My Knife Making Journey - Advice Would Be Greatly Appreciated
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by Stark Knives, Jul 21, 2013.
  1. Stark Knives
    Stark Knives KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Mar 19, 2010
    I just started my first knife today! It's turning out much better than I thought, hopefully my beginner's luck keeps coming. :)
    Starting hacksawing the blade out from the bar stock.
    [​IMG]
    Now I smoothed it out with my 1x30 sander, a half-round file, and a little Dremel work.
    [​IMG]
    It's 1084 from Aldo with around a 3.5" blade and 4-4.5" handle (I haven't measured it yet).
    I just have one question, how much pressure should I use when I start the grind? I'm starting with a new 60 grit Norton Blaze belt.
    Any constructive criticism is greatly appreciated. :)
  2. Stacy E. Apelt - Bladesmith
    Stacy E. Apelt - Bladesmith ilmarinen - MODERATOR Moderator Knifemaker / Craftsman / Service Provider
    Aug 20, 2004
    Take a piece of the scrap from the bar and test the belt with that. In normal grinding, you use moderate pressure to grind the bevels. Start with a few light passes, to get your position and angle right, and then repeat with more pressure to take off the metal.
    Warning - a 60 grit Norton belt will remove steel fast. It will also remove skin even faster. Try and avoid any contact between your hands an that belt. I rarely use a 60 grit belt for smaller blades. On blades with a 3-4" edge, I start with a 120 grit Blue Zirc belt and cut the bevels in a couple of passes.
    Second warning - If your grinder is a single speed unit, that speed is pretty fast. It can pull the blade out of your fingers in a flash, and will heat up the blade to a point where it is too hot to hold in a second or two. Dip in water every pass, and use a push stick or a grinding magnet to support your blade. I use a 9" or 5" grinding magnet to hold most of my blades when grinding bevels.
    Third Warning - Some grind free-hand, and others use a work rest. If you use the work rest, make sure you adjust it so it sits just clear of the belt, but with a minimum of gap. A work rest that "wraps" around the belt is best. These have a "slot" ground into the rest so the side arms go past the belt .
  3. BallewBlade
    BallewBlade
    713
    Oct 10, 2011
    Take bladsmith's advice and then just start grinding, take it slow don't push too hard and I'll bet you start to get the hang of it after about 5 to 10 passes. Those little 1x30 belt sanders work great for the price. Looking good.:thumbup:
  4. Overmountain
    Overmountain KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    May 2, 2013
    I second Stacy's advice about the 60 belt and add just a little more. Even when it seems like enough material was left on, its easy for those deep 60 grit scratches to go so deep they take an eternity to get out. 120 will cut plenty fast and not take such large gouges.
  5. Willie71
    Willie71 Hobbyist Knifemaker Knifemaker / Craftsman / Service Provider
    Feb 23, 2013
    +1 on this. I start with 80 grit, and quickly move up to 120 or 150 once I get the bevels and plunges roughed in. I clean the plunges at 220. I only use the 36 or 50 grits to rough in. Once I get the edge down to .050 or .040", I move to much finer belts. I'm quite new at this, and mistakes happen way too quickly with a courser belt.
  6. Stark Knives
    Mar 19, 2010
    Okay. I'm going to drill the handle holes today. If I understand correctly, if I were to use 3/16 pins for the handle, I would drill the tang holes with something like 1/4 to allow extra room? And when I would do the handle scale pins what size holes would I drill?
    I'll post some pics of the grind soon. :)
  7. Stark Knives
    Mar 19, 2010
    Anyone? I kind of need to know this by tonight so the faster the response the better. :D
  8. Frank Niro
    Frank Niro
    Sep 10, 2000
    You should drill with a 3/16 if the pins are 3/16 . Frank
  9. Stacy E. Apelt - Bladesmith
    Aug 20, 2004
    Frank may be referring to the holes in the handle wood . I always recommend the tang holes be 25% larger than the pins. 1/4" for 3/16" rivets is perfect. If you drill them exact, and there is any mis-alignment, the rivets won't both go in. The little wiggle room makes this problem go away.
  10. Stark Knives
    Mar 19, 2010
    Thanks Stacey! Should I countersink if possible?
  11. Patrickknives
    Patrickknives
    Dec 13, 2006
    I drill the tang holes in the blade the same size as the pin, I do countersink to remove any burr and give a nice spot for some glue.
    Another option is to get a like bar of steel from a hardware store and cut out a couple of test blades, the stuff is pretty soft easy to cut and grind. Seems like a lot of trouble but will save you some 1084. There other nice thing is if you mess up the cheap steel, just keep grinding until nothing is left, this will help you develop a feel the the grinder and belts.
    BTY on a fast moving 60, wear gloves, a simple touch will remove a lot of skin, and no pressure, that is right just touch the belt, it will remove a lot of steel without much pressure and will give you some control.
  12. Stark Knives
    Mar 19, 2010
    Thanks! I finished the pre-HT grind and drilled 1/4" tang holes for 3/16" pins.
    I'll try to get pics up tonight. :)
  13. Stark Knives
    Mar 19, 2010
    Oops, double.
  14. Stark Knives
    Mar 19, 2010
    UPDATE:
    [​IMG]
    I drilled 1/4" holes and I'm planning on 3/16" pins for the handle.
    [​IMG]
    I accidentally touched the handle with a trizact so it got a little shiny. That won't cause any trouble with the handle right?
    I feel like I did a nice lean convex for my first ever grind. I use a progression of:
    Blaze 60
    Blaze 120
    Trizact A60
    Trizact A45
    Trizact A30
    I really like the finish I got.
    [​IMG]
    I was surprised at how well I got the distal taper. The tip isn't too thin pre-HT right?
    [​IMG]
    Edge thickness.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Does this look like a good first grind. Not too thin?
    Any comments are appreciated. :)
  15. Stacy E. Apelt - Bladesmith
    Aug 20, 2004
    Looks good.
  16. Stark Knives
    Mar 19, 2010
    Thanks! So I didn't grind it too thin and the spot I ground a bit on the handle won't effect anything?
  17. Stacy E. Apelt - Bladesmith
    Aug 20, 2004
    It looks fine. You still have to sand everything down again after HT, so a minor smudge won't remain.
  18. Stark Knives
    Mar 19, 2010
    Thanks!
  19. Stark Knives
    Mar 19, 2010
    If I were to make a kitchen knife and wanted to heat treat it with a two brick forge, would I need to HT the handle? If the forge was 9" long and the blade would be about 8" long. The handle wouldn't fit, but is it necessary to HT it?
  20. Stacy E. Apelt - Bladesmith
    Aug 20, 2004
    2BF are good for shorter blades and very simple steels. They won't work well for longer blades, or more complex steel types. I would consider a 3-4" blade length the max they will do well. Part of the tang can be left un-hardened, as long as it gets hardened at least 1" past the blade. I would not recommend anything but 1084 or 5160 for a 2BF HT.
    As soon as you start wanting to do bigger blades or other steels, it is time to build a real forge.
Share This Page
