1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
NWG top speed?
Discussion in 'Shop Talk - BladeSmith Questions and Answers' started by Jason Fry, Sep 16, 2012.
  1. Jason Fry
    Jason Fry KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Jun 5, 2008
    I've got a new NWG that I've just finished. Runs at about 1400, 2400, 4400 RPM with step pullies. I'm thinking that full blast might be good for rough grinding, but the machine sure gets loud at 4400 RPM. Most of the noise seems to be in the pullies and link belt, not the wheels or grinding belt. Is there a "top speed" for the NWG, or for the wheels from USA Knifemaker? I'd like to run it that fast occasionally if it's safe, but I don't want parts flying off at my head.
  2. KHDaily
    KHDaily
    205
    Aug 17, 2011
    Just make sure everything is tight and you should be alright. My suggestion would be if you are wanting to run that fast to take it to a weld shop and have them put some weld on it. That would make it MUCH safer!!
  3. quint
    quint
    Nov 29, 2011
    Honestly I wouldnt run it that fast, mine is single speed toward the slower end and it still hogs some metal off without issue. Dont know if they are necessarily tested for a high speed. Could check over on knife dogs forum as they provide support for them over there I think.
  4. Jason Fry
    Jun 5, 2008
    The frame is actually welded. I increased the spring/belt tension and it got a little smoother, just still loud. May put on the riot gear and give 'er a grind and see what happens.
  5. Bo T
    Bo T
    Feb 12, 2011
    Wouldn't the size of the drive wheel play an important part? What is the actual belt speed in linear feet per minute?
  6. Mudbug007
    Mudbug007
    Nov 29, 2010
    You might also want to check with the manufacturer of the belts you're using. Seems like I read somewhere once that some belts have an "optimum" speed that they like to run at. Running too fast could be destroying your belts before their time is due. I like slower myself. Just seems I can maintain control better.
  7. SBuzek
    SBuzek KnifeMaker / Craftsman / Service Provider Knifemaker / Craftsman / Service Provider
    Dec 7, 2006
    Jason
    We built my brother a welded NWG about 3 years ago,it has a 1750 rpm motor,2-3-4 step pulleys and a 4" drive wheel.His stays on the fastest speed as he does fab work.Makes alot of noise but hasn't come apart yet.
    Stan
  8. Jason Fry
    Jun 5, 2008
    4" drive wheel. With Pi being 3.1416, that translates into roughly equal RPM and SFPM. Seems like the SFPM is 3 or 5% higher than the RPM, but not much. Too early in the morning for math without a calculator.
Share This Page
