The Hammond Game Getter is an interesting device for your deer rifle. Another take on "one gun" to add flexibility to your wilderness system. It allows you to shoot a swaged buckshot pellet at about 900 ft/sec using 22 blanks which are used in the construction business. It's for sure accurate enough for small game. 5-10 cents per shot. 2 groups from different cartridges at 25 yards. I was also very tired when I shot those groups, so what I'm saying is this device seems very accurate in my limited tests so far. The rifles I had access to had iron sights.
Case is wide enough to allow for offset.
Cases that aren't wide enough use a two piece adapter like macace's 2 piece adapters.
Off set firing pin plug.
Overall pleased with this device.
Swaging the buckshot is quick and easy, once the swage is lubed all you do is punch the buckshot pellet through with a hardwood dowel or punch. Insert the swaged pellet into the neck of the case, put a powerjet in the back, and you are ready for small game popping. Now I have to order a 5 pound box of buckshot for about 21 bucks- 650 shots. The shots were at 25 yards. I just aimed for the bullseye-POA, and my POI was lower, which makes sense. I didn't adjust the sights.
Some advantages that I can think of
1. Report is like a regular speed 22-actually a bit less.
2. Powerjets are not exactly hard to get from a hardware store- no restriction, no paper work. In and out. Self scan.
3. Buckshot is pretty cheap. 21-25 dollars for a 5 pound box. In 00 and 0 that's about 650 pellets. EDIT: you can buy 25 pound bag of 00 remington buckshot for about 58 dollars off of precision reloading- that's like 3300 projectiles in double ought.
4. You could cast your own buckshot.
5. Good measure if any "dumb" gun control happened. Most likely a window/loophole for a while. Not sure if powerjets are restricted in Britain? anybody know? EDIT: and no it seems ramsets are not restricted in Britain to my current knowledge.
6. Can be made in cartridges that don't share a "family" of pistol cartridges that could be shot using adapters.
7. Quite easy/faster to prepare compared to handloading ammo. No having to locate primers, and powder.
Disadvantages:
1. Initial start up cost?
2. Only one adapter compared to reloading squib loads and having as many as you can reload. For shooting small game I'm not sure that's an issue.
3. The report is about as load as a 22. handloaded Squibs can be much quieter. Well unless you do some weird experimenting which I haven't done yet, now that I think about it...
Disadvantages:
