1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
Reverse -Curve Grind on blade
Discussion in 'Blade Discussion Forum Archive' started by , May 21, 1999.
  1. Guest
    What is the best way to sharpen these? Traded for a BM Pinnacle. Adivce greatly appreciated.
  2. Corduroy
    Corduroy
    Apr 15, 1999
    A set of V-type sharpeners (Sharpmaker, Crock Sticks, Beaver Teeth, etc.) will let you sharpen a reverse curve with about the same ease as a straight edge. You simply draw the knife down each side while holding it perpendicular to the base and pulling it slightly towards you to reach the whole edge. Just as you would "rock" the knife as you reach the point, you can alo rock it slightly to maintain a constant bevel as it passes through the reverse-curve portion. I've sharpened Brend Talon IIs, my AFCK (which has been reground to a more pronounced reverse curve), and several of my own reverse curve knives in this fashion with great success. If you don't have a set of such sharpeners, you might consider picking one up - they are a very fast and easy way to sharpen any blade shape while keeping a very constant bevel.
    -Corduroy
    (Why else would a bear want a pocket?)
  3. Joe Talmadge
    Joe Talmadge
    Oct 3, 1998
    You might do a search on bladeforums for discussions about the Benchmade Axis, I've included lengthy instructions in some of those threads.
    The bottom line is, I do it just like Corduroy. I do advise considering cutting in some thinning bevels first. As you draw the knife, you raise or lower the handle (depending on which part of the curve you're on) in order to keep the edge exactly perpendicular with the stone.
    Joe
    [email protected]
Share This Page
