- Nov 1, 2000
The Salsa would be a good example... How much stronger is the Ti salsa than the normal Salsa?
Then further reinforced stop pin is in order? I wish Demko approached spyderco first.
What about a hollow stop pin? 1mm wall thickness?
So reaming to a 1/4" pivot and a solid 1/4" stop pin would be best? I'm down!
Hahaha, yeah, I suppose that would be hard to beat.
When you do, make sure that you don't thin out the liners/scales above the stop pin too much.
Also, pics when you do!
I think it really comes down to the shear strength of the stop pin. At some point those screws will crack through the liner and the lock will fail. With this in mind, i dont see liner or frame making any difference
Frame compression lock ala the ATR?
Ahh JNewell that makes perfect sense. so what is the limiting factor to lock strength on the compression lock? How much liner material surrounds the stop pin?
