why notBack to the top?
The technique is simple. Lay the blade flat on the leather and push forward while raising the spine in tiny increments. At some point the edge will bite into the leather - that's the angle that you have no choice but to work with because it happens to be the actual angle of the edge.
Once the edge bites pull back with light pressure and at the end of the stroke just stop - stop and pull the blade up and off the leather.
If you pull the blade off of the leather at the end of the stroke in an arc, which is a very normal thing to do, you will have undone all of your work.
I polish the bevels on most of my knives. The bevel feels very slick on the leather when the angle is just right (all my edges are convex). If the angle is too steep, the edge drags (obviously) and it feels rougher. Same deal if the angle is too shallow, causing the shoulder to drag.
The more I do it, the more I'm inclined to use as light amount of pressure as is possible (just enough to maintain consistent contact with the strop, without 'skipping' across the leather). I figure if I'm needing to lean into it very hard at all, it probably indicates I didn't quite finish the job with my hones.
Since no edge is absolutely perfect (yet, but I'm still working on it ), and there's always at least a very tiny rounding off at the very edge, I'll make a couple of very, very light passes with the angle elevated just a little. In effect, I look at this as polishing the 'microbevel'. Seems to give it just a little more 'bite'.
To Twindog:
Your string & wedge 'visual aid' is excellent. Very simple & a great way to illustrate the concept. Nicely done! :thumbup:
Bump to the top again....this explains so much with pictures. I've read way too many long posts on stropping and this pretty much covers it.
Bump...
I think you are on a mission from God. :thumbup:
Nice to see you back!
Stitchawl
I can spend between $2 and $1000 for a knife. Should I get a folder or a fixed blade. Custom or production. HELP!
