1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
Which of my knives is best for survival/bushcraft?
Discussion in 'General Knife Discussion' started by sja2249, Jul 10, 2012.
  1. sja2249
    sja2249
    173
    Feb 11, 2006
    I'm on a very limited budget and am hoping that one of my fixed blades will be suitable for survival/bushcraft use. I have a fixed blade in my bugout bag, but I'm thinking about changing things around.
    What tasks should I worry about and what kinds of knives are best for those tasks? I initially approached this with the idea that I didn't need a heavy/stout knife, just one that cuts well. I had figured that my knives would be used for food prep, cutting cordage, making fuzz sticks, striking a ferroceum rod, etc. I never planned on doing any chopping...
    Right now, my fixed blades consist of:
    Buck 119 Special
    Cold Steel Government
    Benchmade Nimravus Cub
    Mora Craftsman
    Mora Clipper
    Mora Classic
    Mora 2010 Outdoors
    Marttiini Big Game Hunter
    Right now, the Mora Clipper is in my bugout bag. Should I rethink this? Or perhaps supplement?
    Thanks.
    Sam
  2. bladeboss
    bladeboss
    Mar 6, 2012
    Moras. Cheap, strong, and if they do break, you're not out much
  3. marcinek
    marcinek
    Jan 9, 2007
    Except when you are in a survival situation. Then you are out your life. :)
    If you have used your Clipper in the woods, and the only place you typically bug out to is the woods (why do people always run off to the woods?), then it will be fine.
  4. blt-2-drg
    blt-2-drg
    436
    Feb 6, 2012
    Which ever is most comfortable to you and fits your needs best.
  5. bladeboss
    bladeboss
    Mar 6, 2012
    True..
    (Get/carry more than one.)
    You can get lots of Moras for what one Nimravus costs
  6. Bigfatts
    Bigfatts
    Mar 12, 2012
    I would say either the Marttiini or the Nimravus.
  7. kvaughn
    kvaughn Gold Member Gold Member
    Dec 28, 2005
    That Buck is a true classic and has filled the needs you refer to for many people for many years. Plus it would probably be tougher{full tang] than the Mora's.--KV
  8. sja2249
    sja2249
    173
    Feb 11, 2006
    This isn't about me buying new stuff for survival/BOB/etc... Those are the knives I own... I'm just trying to decide which ones are best for my purposes. I actually have 2 Nimravus cubs and probably 10 mora knives. I currently have a mora in my BOB. I'm thinking maybe I should replace it with a sturdier knife or perhaps add a sturdier knife to the BOB in addition to the Mora. I can't afford to buy any new knives at the moment. In fact, I'm likely going to have to sell a few knives in the near future.
    Thanks for the comments/suggestions.
  9. sja2249
    sja2249
    173
    Feb 11, 2006
    The Special is full tang??
  10. umberto00
    umberto00
    215
    Jun 25, 2004
    Quick question: which of those knives do you use the most for bushcraft? That would probably tell you your answer right there.
  11. sja2249
    sja2249
    173
    Feb 11, 2006
    So far? The Mora Clipper... but I have pretty limited bushcraft experience. Mostly just making fuzz sticks, small traps, and shaving fatwood.
    Sam
  12. wildmike
    wildmike
    Nov 17, 2007
    The mind and the hands guide the knife. Practice the skills and they can be performed with nearly any halfway suitable tool.
    I.e I have performed fine notching, and made fuzziness with an 18" M43 Kukri. While not being the ideal tool for the job it did it just fine.
    All of the knives you listed can be pressed into service and will function well. I would make the nimravus or the buck your primary and relegate the more to a backup blade. Make sure they all are very sharp, and take a sharpener with you in your kitchen to touch the blades up in the field.
  13. EZ Bake
    EZ Bake Gold Member Gold Member
    Mar 5, 2009
    Get a Spyderco Ladybug. Real men use Ladybugs for survival.
  14. not2sharp
    not2sharp Gold Member Gold Member
    Jun 29, 1999
    From your list, I would go with the Buck 119. It is a tried and true utility knife.
    n2s
  15. sja2249
    sja2249
    173
    Feb 11, 2006
    The bugout bag has diamond hones in it. I always figured maintaining the edge would be nearly as important as having the knife.
    There's also a multitool in the BOB with a diamond coated file. I always have a multitool on my belt, which also has a diamond coated file. I keep a credit card sized diamond hone in my wallet, and I always have my Benchmade AFCK on me. I *SHOULD* be set for sharps and hones.
    Thanks again.
  16. sja2249
    sja2249
    173
    Feb 11, 2006
    :) Thanks!
  17. Foilist
    Foilist
    Dec 20, 2004
    Stick two Moras in there. You have a spare to lend, trade, or replace a lost or damaged one.
  18. sja2249
    sja2249
    173
    Feb 11, 2006
    Anybody want to expound on the pros/cons of the 119, Nimravus Cub, or Sog Government for bushcraft/survival needs?
  19. djjonny
    djjonny
    Jan 11, 2012
    My vote is for the Buck 119. Sentimental reasons having one.
  20. paul'ie
    paul'ie
    436
    Jun 6, 2012
    I'm a 3 knife man, a neck knife, mid-size knife, and a chopper, just make sure the knife that's on you, is a dependable knife, that you can trust your life on it, the knife that's on you is the best knife, my favorite set is the Busse Sarge 7, Anniversary Mean Street, and my H.I. M-43, the knife that would be on me is the Sarge, on my O.K.C. set, T.F.I., SP-53, and my BK-14, I have the T.F.I. on person, get the picture, the best survival/bushcraft knife is the knife you have on you.
Share This Page
