1. Welcome to the New & Improved BladeForums. New software info here. Please report problems in Tech Support, and read existing threads before posting! - Spark
  2. I've changed the default forum style to Flat Awesome based on feedback. Don't like it? Click here to change how the forums look Feedback on this is welcome here.
Will using a grinder to sharpen a Kukri or any knife lessen its hardening?
Discussion in 'Himalayan Imports' started by HighlanderNorth, Jul 3, 2012.
  1. HighlanderNorth
    HighlanderNorth
    43
    Jun 23, 2012
    Obviously when a knife maker hardens a blade, they use heat and quenching to make it harder. Well, if you put your blade on a power grinder to sharpen or repair it, then the friction caused by the grinding will heat up the blade, and might that lessen the hardening, make it softer or make it more brittle?
    I dont plan on doing that, but I've certainly seen people use grinders to sharpen or repair larger blades, and even some smaller ones. I guess if you really put a dent or take a chunk out of your blade, you might be forced to use a grinder, but will that have an effect on hardness?
    How do YOU sharpen your Kukris and your other knives?
  2. Karda
    Karda Banned
    Jun 1, 2007
    In short, yes, a grinder, belt sander etc.... can tend to anneal a blade if it is not done carefully and the blade kept cool.
    If you are grinding on a blade and you see colors or black (burned) you have messed with the heat treat.
    Myself.... i never like to let my blades get hotter than i can hold in my hand.
  3. KyleGrantham
    KyleGrantham
    71
    Jun 13, 2012
    When the blade gets hot just dip it in some water.
  4. HoosierQ
    HoosierQ
    Feb 9, 2010
    Too late. Now if you had some sort of slow speed water cooled set up that would be a different story but if it gets hot, its too late.
  5. bemo
    bemo
    493
    Oct 19, 2006
    As usual, Karda has the answer: too hot to handle = messing with the heat treat. The thinner the metal, the faster that will happen. Particular care needs to be excercised with the point of kukri as the rest of the blade has a lot of mass and won't heat up as fast as the thinner metal at the tip.
  6. t1mpani
    t1mpani Platinum Member Platinum Member
    Jun 6, 2002
    You can completely change the primary grind on a blade without affecting the temper if you know what you're doing. Hell, some knife makers don't even do the primary grinds until after HT. I keep the thumb of my support hand on the edge at the opposite side of the blade when using a grinder. If you move at a consistent speed (I do about a belt-width per second) and dunk in water every four or five passes, you'll hardly ever get to the point where your thumb feels much heat at all. Heat builds faster with finer belts, so always finish reprofiling with coarse, and save the fine stuff for finishing/smoothing.
    It's like most things---if you know what you're doing, it's fine.
  7. Karda
    Karda Banned
    Jun 1, 2007
    Well, it takes quite a bit more than too hot to handle, but if you're working on it and it's too hot to handle...whats the point?
    Not only can't you work on it, but you could anneal your edge, especially with khukuri where the edge tends to heat up alot faster and the mass of the blade holds the heat. I always advocate and practice caution.
  8. gomipile
    gomipile
    Apr 17, 2010
    As mentioned above, you can use a wet grinder (preferably with a SiC wheel) for reprofiling. For sharpening, paper wheels on a regular (3450 RPM) bench grinder motor can be used quite effectively.
    But regular hard abrasive wheels on a high speed grinder? No, that'll ruin the heat treat faster than your reaction time.
  9. t1mpani
    Jun 6, 2002
    I was talking about a belt sander. Dry, stone wheels on tempered steel is definitely bad juju.
Share This Page
