I agree, have the service available to those who want it but not mandatory, tbh if it's mandatory I will probably back out or completely regrind the profileAt the very least make the JT provided profiles optional. I’d like to make something of my own, not just a variation on a common theme.
For the 2019 KITH, you were not required to get a blank from JT but could also profile and heat treat yourself. The three designs were fixed, though. Looking back through the thread, I think two of the finished knives were heat treated by Warren and three were blanks from JT. The drop-out rate for that KITH was pretty high, JT posted that he had sent out around 60 blanks.I will do whatever, but being in new zealand the logistics are a bit tougher so prefer to do my own
JT will Cut whatever profile you want. I don't know if he wants to do a special rate for this one or not but you can just get a large blade and grind it into your own profile. If anyone isn't good at doing their own HT it would be the right thing to do to get it professionally HT'ed. We are all at different levels but its not fair to give others a blade that isn't usable. I will let Willie71 add any restrictions but a useful blade should be a minimum. It's not a way to just get a nice blade but a way to get someone to take a good look at your own work.At the very least make the JT provided profiles optional. I’d like to make something of my own, not just a variation on a common theme.
Wow, that was quick. And here I was thinking I'm ahead of the curve with some profiled blanks...
Kitchen knives are a new territory but started on this one. S grind is roughed in.
Hmmm. I was thinking about doing a nakiri too. Maybe I will switch it up,I have three AEB-L nakiri blanks that I heat treated a few weeks ago. My plan is to grind and finish all three of them and then send in the nicest one. The blade length is a bit shy of 170mm, but Willie71 said that is ok as long as it isn't a paring knife. The cell phone picture below is not the greatest, it makes the blade look wider in the front.
This is my first KITH and I am pretty excited about it. I'd like to see what everybody else is planning to do.
What steel is are you using?
I think you should do what you want to do and not let what somebody else makes influence your decision. There will likely be more than two similar knives if all sixteen people that are in as of now finish a knife.Hmmm
That is pretty quick compared to my pace.1095. As this is new I wanted something I wouldn’t feel bad about messing up. Only took about 45 min to rough in.
