- Jul 14, 2002
Hello everyone. . .as some of you already know my dad and I like to make interesting clips, and over the years i've almost become obsessed with clips. And since we came up with the 'grip clip' concept i can't carry a knife without one. So i took it upon myself to make aftermarket clips that fit production knives, the first knife that I picked is one of our designs for Kershaw, the R.A.M.
The idea behind the 'grip clip' is simple. . .when you put the knife in your pocket you squeeze the end, which lifts the tip allowing the clip to slide over the pants pocket easily. And when the clip is released the clip grips the pocket for a secure carry. To get the knife out you again squeeze the clip relieving the tension allowing the knife to slide out.
If you've ever had difficulty getting your knife in and out of your pocket you'll understand right away how nice it would be to have the clip lift up and over the pants lip. Getting a pocket clip to work properly is a delicate balance between too tight and too loose. Obviously too tight is a major pain, but once it's forced into the pocket you know your not going to loose your knife. A clip that is too loose is easily taken in and out of the pocket but then you run a higher risk of loosing the knife. The 'grip clip' is meant to solve this problem. . .
Check out this thread for more information http://www.bladeforums.com/forums/showthread.php?p=6891862#post6891862
(( Wrong forum, wrong membership level for selling. ))
Gavin
Photo by Phillip Dobson aka firebert
Photos by Glenn Eisen aka kneedeep
Gavin
