- Jun 22, 2003
for those who use paracord to wrap the handles of their escrima's - here is an example of another type of knot you can do besides the strider or blair stix style wrap.
its a basic turks head knot, with one differnece. instead of just making a turks head knot, you start it off at a lanyard hole. with one end of your cord, you make a figure eight with the center of the 8 going through the lanyard hole. you take the long end of your cord and do the turks head. every time you come back around, you loop the cord through the 8, so that you have a stationary lock on the entire knot, so it cant slip up or down the stick. what you end up with is a weave pattern that is very tight, and stationary. the main problem i have with other wraps, especially with askrima sticks, is that if you do any kind of thrusting, the paracord loops will shift forward leaving patches of the stick visible in the handle wrap. wich can get pretty annoying, and if bad enough, start to effect the function of the handle.
just thought ya'll might want to see it, it turned out rather nice.
the reason its so short is because in order to make it longer, i wouldnt have had to spend another hour or 3 on it adding weaves, and its pretty dificult on a pole. you have to use tape to keep the top of the knot stable so you can see what your supposed to do and not have it mash down and get all cluttered.
