- Oct 5, 1998
I had posted this elsewhere, but I thought I would try it here as well:
On my AR, the asymmetric washer in the pivot does not rotate with the blade. This causes a failure to lock when the blade is opened.
The knife functioned perfectly until I took it on several dives (salt water). After the second, there was what appeared to be rubber cement coming out of the space between blade and washer. Once this material was removed, the pivot was very loose and lock up was sporadic from that point forward.
My question: Is there adhesive or a rubber washer which retains the position of the asymmetric washer?
I will take advantage of your great warranty and send the AR back to you (once my back up AR comes in), but I would like to know in case my knife lube is degrading a fragile spacer/adhesive. I have used everything from Break Free to Tri-flow to 10W40 to Hawaiian Tropic on it with good results, until it hit the salt H2O.
Thanks,
Mark
Thanks,
Mark
