<a href="http://www.canit.se/%7Egriffon/knives/almar/falcon_side.jpg"><img src="http://www.canit.se/%7Egriffon/knives/almar/_falcon_side.jpg" align=right></a>Yesterday, I got the second knife I've ever purchased before checking it out in person first, and this one too <strong>is just as good as I had hoped, or rather <em>at least</em> if not better</strong>.
The first thing you notice is that it's <strong>really, <em>really</em>, light</strong>. Numbers alone, 34g, doesn't do it justice, as it's not particularily small. In spite of this, it doesn't feel the least bit flimsy, but <strong>sturdy and solid</strong>.
The second thing you notice is the <strong>excellent workmanship</strong>. Fit and finish is on par with knives costing a lot more.
The third thing is the good ergonomics. The handle fits my hand perfectly and it seems to fit a wide range of hand sizes. The point is dropped just the right amount that it becomes easy to use it on a flat surface without having to angle the handle up too much, while having a good curve on the edge for slicing cuts.
<a href="http://www.canit.se/%7Egriffon/knives/almar/falcon_clip.jpg"><img src="http://www.canit.se/%7Egriffon/knives/almar/_falcon_clip.jpg" align=left></a>
Mechanism is an ordinary lockback, there are thumb studs on both sides and the clip can be fitted on either side, but only tip up carry (regular readers will know I don't really have a preference for tip up or down).
There's no lanyard hole, unless one can consider the one where the clip is mounted as one, which I actually think is a <em>good</em> thing, as lanyards are actually useless most of the time.
Steel is AUS8A, the blade is about 2 mm thick and tapering which makes for good cutting performance, blade length is 80mm. Excepting the clip, the knife is about 8mm thick.
I'm <em>very favourably impressed with it</em> so far and think it's probably overlooked and too little known, as I'm sure more would like this kind of knife.
Urban Fredriksson
Latest updates Moki Hana, Fällkniven WM1 neck sheath, Moki Blossom and Fällkniven S1
"Smooth and serrated blades cut in two entirely different fashions."
- The Teeth of the Tyrannosaurs, Scientific American, Sep 1999
Urban Fredriksson
