- Oct 1, 2000
Here is the problem. Say you have a completed the heat treatment and tempering of a ATS-34 blade and spring on a slip joint folder. You then find yourself needing to slightly bend the spring to make things line up correctly (read straighten).
What is the best thing to do:
A: use a torch to heat and straighten the spring and then re-temper twice.
B: use a torch to heat and staighten and then re-harden and re-temper twice
C: use a torch to heat and straighten and use the spring after it cools (no heat re-treat or re-temper)
D: throw faulty spring in the trash and rebuild new spring for folder
E: ????????????? Another idea. Tell me something else
Thanks
Thanks
