Watchful said:Obviously there's a factor working against you:
- Your distance to the target. Try 14'-6" or 15'-6" and see if it improves or worsens.
can only go a little past the 15" mark with IKTOF rules
- Your grip. Try a blade throw vs handle throw.
has to be blade throw
- Your release point... try releasing a fraction sooner.
you are right about that, the flick of it is about the only way i can get it to stick, it is sticking alot more now, thanks...that might have been the problem
- Your knife. Does it not have enough mass to stick deeply?
these are all tournament regulated distances
Kevin the grey said:Try throwing a little harder which will have a twofold effect . It will give you a slightly flatter trajectory and perhaps eliminate or lessen a waffling effect .If you throw harder give your arm time to get used to it . It may take a couple of sessions before you settle in to your new throw .
Remember--always--that there is a practical limit to most non-rotational throws. It's pretty much a matter of your arm length, but compensating your throw to keep the knife level will shorten your distance dramatically.Kevin the grey said:Like I said I can do it out to four feet and then there is no control whatsoever .
Watchful said:Remember--always--that there is a practical limit to most non-rotational throws. It's pretty much a matter of your arm length, but compensating your throw to keep the knife level will shorten your distance dramatically.
REPLY > When I am at one with the cosmos(about once a millenia .) I throw underhand rotation with a heavy blade .The tricky thing here for me is that the knife is lower than the target at the beginning of the throw and then higher as it reaches its arc and then descends into target range . I,m not bad and if I did the smart thing and actually practiced I,d be o,kay .
As for non-rotational I,ll think about your angle of it being a matter of the length of your arm . The question here is the release must be almost perfect . If not it doesn,t have much of a chance to stick .
Rotation conceals and forgives error in both form and knife .What do you think ?
I don,t have an indoor spot to throw . Its started to snow where I live which makes for stiff fingers and hidden misses . I,ll keep throwing my hawks for a while . They are easier to find . Not that I ever miss ! ! L:O:L
That's an interesting idea--I'm sure lots of people have done this, but it seems like a "slower" throw to me. I can easily do a non-rotational underhand at 15 feet... it doesn't need to arc as much, but it's several miles an hour slower than a rotational overhand.Kevin the grey said:I throw underhand rotation with a heavy blade .The tricky thing here for me is that the knife is lower than the target at the beginning of the throw and then higher as it reaches its arc and then descends into target range .
Rotation takes advantage of the conservation of angular momentum--which means as the knife rotates, it tends to correct yawing. No trick here--a rotating object tends to use less energy as it spins smoothly around its axis, so it would take *more* effort to get it to travel sloppy.Kevin the grey said:Rotation conceals and forgives error in both form and knife .What do you think ?
