Atlantic Salt Impressions
Smoke
Just got a PE Atlantic Salt, as I wanted to try H-1 and have always liked the look of the Rescue series.
Out of the box, the grind lines of the blade are a bit rough and the knife feels more blade heavy than other the zytel Spydies. Opening and closing is smooth but not as crisp as the G-10 Spydies I've held. The large Spyderhole, the thumb and choil serrations work very well.
I've cut cardboard, tape, rubber, and whittle some cherry wood and the Salt reminds me of the ATS-55 Standard. With gloves, I find the handle of the Salt a bit thin, so aligning the edge takes a bit more conscious effort
There is the 'normal' vertical play but there's also some lateral flex. However, I've noticed a paper thin gap between the zytel and the metal parts. Overall, I'd like the Salt to be a bit longer overall or in a thicker, G-10 version. I'd also like to see the Spyderco trainers in H-1.
Nice review of the Atlantic Salt.
I have a SE Salt I and I am very pleased with the rust resistance and edge retention of its H-1 steel. I was thinking about picking up a PE or SE Atlantic Salt for several reasons: H-1 steel, its larger than the Salt I, sheepsfoot blade, & finger choil. Just from looking at pictures it appears as if the handle of the Atlantic salt is very similar to that of the Rescue 93mm handle, which is the right length and thickness for me.
I am wondering why you would want a trainer in H-1? I have never used a trainer but I would guess that the blade steel for trainers is irrelevant to its function. It's not like one would be training near a salty environment :confused: ;)
PSU, sometimes my sweat and/or my training partners sweat get on the blades.
My Spyderco trainers have done real well after 3 years of use but lately I've been finding rust spots, even after putting a layer of Tuff Cloth. I figure H-1 might be slightly easier maintenance.
BTW, I'll make you a good deal if you want my Atlantic Salt. :)
What would the point of having the trainers have H-1 Steel?.:confused: Looks like Someone posted the same thing first
