Not actually. WD40 is hydrophobic. The WD stands for Water Displacement, with 40 being the 40th formula tried. It does not retain moisture. What it does is displaces moisture, and if you don't treat the space that the moisture vacated from with some form of sealant or lubicant, moisture will get back in. For the BM 4x series (damn it, can we just call them the new Ti Series) it'll work great as a cleaner, but you'll need compress air to blow out the residue WD40 before the Miltec has a surface to grab onto.Originally posted by Hawaiian
WD40 is a great cleaner, or degreaser, not a lube. It also retains moisture.
The new Ti series from BM should not be loose. They have washer that serve as friction barrier, and if properly installed, should not have any gap for the blade to wobble. But you are correct in that any non-water based lubicant will extend the life of the bali. It's just that after trying household grease, Synthetic motor oil, Tuff Glide, White Lighting and Miltec, for me the Miltec seems to bond better to the bali's metals than the others, and doesn't trap dust like some of the other lubes. Whatever works for you. I'm sure if the next best thing comes around, I'll tyr that when I run out of my Miltec 1.Originally posted by wire edge
Is Miltec really that much superior, considering the relative looseness associated with Balisong actions? Can the wearing of parts really be compared? Say, one new in the box BM 42 with Tuff-Glide, and another with Miltec? I think this whole issue is merely a "feeding frenzy" that fuels new product sales. What do you guys think?
