Jeff; full marks. I believe Timken Latrobe to be the sole manufacturer of BG42, technically 'Lescalloy (r) BG42 (r) VIM-VAR High Performance Bearing Steel.' BG stands for Bearing Grade.
As the name denotes, the steel is purified by Vacuum Induction Melting - Vacuum Arc Remelting. This yields a very pure steel which can yield a very fine grain structure. For full details on this steel, go to the TL website:http://www.timken.com/latrobe/technical_info/bearingfax.asp
Neither ATS-34 or 154CM are purified by VIM-VAR, although the resurgant popularity of 154CM is due to its' improved purity, obtained through a different process. Here is a Crucible Particle Metallurgy metallurgists' comments about this, courtesy of Joe Talmadge on KFC:
One myth from that time that continues to plague the grade is that
154CM was vacuum re-melted. This grade was never produced with vacuum
re-melt technology. At the time it was air melt material. Today it
is melted differently...
Like I said earlier,
many years ago, this material was produced by air melt technology.
Today it is produced by the Argon/Oxygen/Decarburization process
(AOD). This is the primary way to produce quality stainless steels.
It is not as clean as re-melted steels but is about as close as you
can get and is much cleaner than 15 years ago. 3 years ago when we
entered back into the 154CM market we were concerned that the ATS-34
was cleaner than ours. We found just the opposite. They do not
re-melt their material either and in numerous tests with knife makers
and polishers our material was much cleaner. Based on our sales and
responses from our customers, the myth of the dirty 154CM is behind us
for good.
I mention the AOD process as it is possible that it is utilized in the production of VG-10; I was unable to find out the details of this steel, other than its' elemental composition. Does anyone know who produces it?
I mention ATS-34, as it is basically VG-10 with minor changes. VG-10 has slightly more Cr, a dab of Co (1.4%), a little more Mn, and 0.2% V, but only 1/4 the Mo. One would expect these two steels to perform in a similar manner.
BG42, on the other hand, is not only cleaner, it has an elemental alloy advantage, with the 4% Mo of ATS-34 and 1.2%V yielding lots of hard V carbides. One could reasonably expect this steel to outperform ATS-34 or VG-10. Certainly Chris Reeve switched from ATS-34 to B42 for a good reason.
Hope this helps,
Walt, Certified Spec Sheet Guru
