Here is how to obtain a technical info sheet for BG-42 steel. Go to this URL:
http://www.timken.com/latrobe/technical%5Finfo/backup%20copies%20of%20fax%20pages/bearingfax.htm
Type in a fax number, and the info will be faxed to you.
Here is the method for finding this info for other alloys. Go to this URL, the main metallurgy site on the net.
http://www.mlc.lib.mi.us/~stewarca/metallurgy.html
Then click on ASM International. Then click on ASM's Alloy Digest Web Faxx, then enter the alloy for which you wish to search. You should be at this URL now:
http://asm.micronexx.com/search/iatoc
This gives you three different types of BG-42, all made by the same company, Latrobe Steel Co. You can spend $25 here, and they will fax the data sheet to you (look at the sample data sheet on the site to see the data contained therein). There is a cheaper way to do this, as most manufacturers will supply the info free. Go to this URL:
http://www.asm-intl.org/www-asm/matprod/matp_0.htm This is reached by clicking Directory of Material Suppliers on the ASM home page.
Click on Metals Suppliers Online, and you will go this URL:
http://www.suppliersonline.com/ click on Go For It, and then click on Find a Supplier, and enter Latrobe Steel Co in the search box.
Now, you are here: the Timken Latrobe steel home page:
http://www.latrobesteel.com/technical_info/index.html click on search, and enter bearing steels, and you will end up with this URL: http://www.timken.com/latrobe/technical%5Finfo/backup%20copies%20of%20fax%20pages/bearingfax.htm
This gives you a selection of steels which you can have faxed to you free. There are some steels whose data sheets are in the Adobe (.pdf) format, but these are generally the newer ones, not BG42 Hope this helps, walt
