I do not know of any sites that have this kind of instruction
You will tho , work it out very easily .
When you are whacking a log , or just taking down a sapling for a tent pole , try not to treat your knife like an axe and just hit into the wood , your knife is a knife not an axe , you have a long cutting edge , and that is key to using the knife , as you cut your target , slice it .. itll take a few tries to get the hang of , but once you do , youll find your bigger blade is actually a kind of super tool ... its FUN when you get into it as you cut , draw your blade thru the cut , I think it is like a 4x increase to your effective cutting power .
for smaller finer work , opening fish , skinning goats ... I use the blade up near the handle a lot for delicate stuff , instead of poking the point thru the hide to peirce it , I pinch the hide up and slice out like a button of skin to get an opening into it , and just carefully open the hide up from the top down rather than sliding the smaller knife under the skin and cutting upwards .
when it comes to making fuzz sticks , a longer blade is actually ideal .. you can jam your wood youre working against another bit and use your blade as a draw blade .. with some practise , you will be peeling off shavings like a wood working plane in a workshop .
That same skill will make a branch into dressed timber if you need it .. for overnight camping , this is no big deal , for longer term tho , you can want some improvised gear in your camp , this is a big headstart , in my experience .
I dont have a golock but a long machete , I baton with it often , I am more accurate at splitting wood this way than I am with a hatchet .. I DO need hatchet practice true but with no practise with my machete , I place the blade where I want the split and hit it and there is my split
I sharpen my machetes as if they were knives , if I ding up the edge Ill try to steel if straight before deciding that its got to be ground out ... I generally use just a fine stone , and strop it on cardboard , or my belt . I convex my edges . I found in my experience that the knife keeps its edge pretty well , and is more useful for stuff beyond hacking plants up if it is properly sharp . I feel too ( no way to actually measure ) that it takes less effort to cut for longer periods too , like when I am clearing a path to some of the sacred sites I still visit around here . They do not see traffic any more , and the old paths get so over grown you do have to cut your way thru , grasses vines , light - medium brush . I feel less fatigued doing it with a tool that I keep shaving sharp anyway . I feel it takes less effort to return to a good edge as well when it does lose its bite . This is only my personal finding / opinion tho .
The best way to learn to use your new toy is to take it out and play with it
Enjoy !
