- Feb 6, 2000
I got a Swamp Rat Battle Rat a few months ago and Cliff was kind enough to lend me his BK9 a few months ago also (before he got to use it). By now, I've had more than enough time to evaluate these two knives.
First, some specs:
Becker Combat Bowie 9
Length, Overall: 14.5"
Blade Length: 9.25"
Blade Thickness: .210"
Grind Height (to edge): 1.5"
Blade Material: 0170-6C
Handle Length: 5.25"
Handle Thickness: (avg) 1.125"
Handle Material: GV6H
Weight: 14.9 oz
Sheath Material: Propex Nylon w/Kydex Insert
SwampRat Battle Rat
Length, Overall: 14.25"
Blade Length: 9.25"
Blade Thickness: .250"
Grind Height (to edge): 1.4"
Blade Material: SR-101 (differentially tempered)
Handle Length: 5"
Handle Thickness: (avg) 0.75"
Handle Material: Resiprene C
Weight: 15 oz
Sheath Material: Cordura w/Kydex Insert
Here are some comparison pics (along with some other knives):
http://members4.clubphoto.com/a318774/1101600/guest.phtml
These knives fulfill very similar if not identical roles. Whether that be camp knife, combat knife, etc., they are in the same niche. However, there are some differences.
The BK9's Balance point is about an inch in front of the handle material, fairly neutral. The Battle Rat's balance point is about 1.7" from the handle material, and makes the BR more geared toward heavy chopping.
The handles are very different. Which one you like will probably make a big difference as to which knife you prefer. The BK9's is much wider and a little larger. It is made of a hard plastic that is not too grippy (this has been discussed a lot before). It is contoured pretty well, although it is a tad squarish, and its thickness spreads the load very nicely. The holes for the screws are somewhat abrasive. The main thing I don't like about these handles is the rear part. It is "knobby" and makes choking down on the grip for heavy chopping uncomfortable. Overall, IMHO a nice handle that could be improved with more contouring and a more aggressive texture (minus the holes).
I made new handle scales out of wood for my PM as you can see here:
http://members4.clubphoto.com/a318774/1036231/guest.phtml
You'll have to ignore the Knight Light (good luck
) in the album. I've filled the holes with epoxy by now, BTW.
The Battle Rat has a thinner handle that is of a great material called Resiprene C. This stuff feels like a hard car tire and seems to hardly ever give blisters. The handle is nicely contoured and the texture is about perfect. It allows one to choke down comfortably. The only thing I would like to change on this handle would be to increase its thickness to that of the BK9's.
The sheaths are quite similar; pretty nice. They have a kydex insert and a nice pocket for firesteels, sharpening stuff, etc. However, the BK9's sheath has major flaw. The knife rattles like crazy!!!! It is lowd, incessant, and intolerable. However, there are ways to fix this, like stuffing a piece of cloth down there or remolding the kydex tighter. I decided to make a new kydex sheath for it (multi-carry), which can be seen here:
http://members4.clubphoto.com/a318774/1101691/guest.phtml
Now, some miscellaneous stuff. First off, the BK9 has a "hammer pommel". I've never had a use for those things. I use the face or spine of the blade to drive stakes or similar and never crush boulders. Besides, if you miss slightly when hammering with the pommel your hand is in for some damage. However, it doesn't detract from anything, so no problem.
The BK also has a pretty nice thumbramp on its spine. However, the grooves are so deep and wide that it is not very comfortable (in discussing this with RokJok, we decided it was designed for use with gloves). The BK's tip has a false edge leading up to it. This thins the tip down, which looses strength but helps with fine work. However, with a blade this large I would not use its tip for finework. I prefer teh BR's point, which is a strong clip point with a "penetrator tip" (two tiny false edges on top of the tip that make the tip very sharp). The BR's tip is stronger and yet pointier.
The BR has a very nice finger cut-out in its choil that is infinitely useful. It makes fine work many times easier. The BK doesn't have one, which is a big disappointment. Of course, one could add one with a dremel or similar.
The coatings are similarly durable, but the BR probably has the edge. I chop mostly softer wood however, so this isn't a very large issue. BTW, if you remove the coating of the BR, you're rewarded with an awesome temper line!!
The BK's NIB edge was thinner than the BR's, but not by leagues. I thinned down the BR edge until it was about like the BK's, then I did most of the testing comparing the two. Both edges were shaving NIB, but the BK amazed me. The edge was RAZOR sharp.
Now, on to chopping. I could go on about this for a long time, but here's the overview. The BR had more power and beat out the BK in heavy chopping, especially on hard wood. As an example, the BK would, on thick, hard (dead) wood almost bounce off, while the BR would still bite in. The BK has more neutrally balanced and beat out the BR in machete-like chores and small and soft wood. For example, the BK would clear brush with less wrist fatigue than the BR (though both are not really suited to the job). Both were good choppers.
Fine work went to the BR with its great choil, thought he BK didn't fare badly. I could just get more control with less wrist fatigue with the BR.
Both knives seem durable, though the BR is probably significantly ahead of the BK (after seeing the performance videos). The BR is differentially tempered and extremely tough. The BK, however, is far from weak. I used it to split firewood with full swings from a hammer, and, apart from coating damage and a little denting from off blows, was fine.
Edge-holding was comparable, but the BR seemed to hold its edge better. Also, while I didn't do destructive testing, I accidently hit small rocks with both blades. This is only my impression, but the BK's edge didn't seem as durable as the BR's. I only lightly hit a small rock with the BK edge and it dented the edge quite a bit; with the BR it took a more powerful swing to do that. However, no chipping on either, so no problems.
Sharpening was favorable on both, but the BR is unbelieveable! SR-101 ("52100 with kryptonite") takes a razor edge effortlessly. This steel is great for people like me who are not sharpening experts. One can achieve a shaving edge quite easily. Also, the BR's steel responds well to stropping. The BK also sharpens quite easily, though not as well as the BR, and responds well to stropping.
Overall, I would give the Battle Rat the edge for my uses, but it's pretty close. Both knives are very good performers.
Sorry this has taken so long, but I hope this answers some questions.
Any questions, fire away
First, some specs:
Blade Length: 9.25"
Weight: 14.9 oz
SwampRat Battle Rat
Blade Length: 9.25"
Handle Length: 5"
Weight: 15 oz
