BM 760 low rider clips
I really don't keep up with the BM numbers so well. Show me the folder clip side and we'll go from there.
If I don't have the knife I will need it to make it unless you can take precise measurement from the mid-line of the two far set screws to mount the clip to the top of the folder to allow me to know where to make the fold over for the low rider.
Again, thats from the middle of the screws right across the place where you stick the driver to remove them to the end of the folder. How far?
Once I know this if I already have the pattern which I will have if its a BM I can copy, then I can fold it and ship without the folder.
Otherwise I need the knife. Oh, and I ask anyone doing them this way through me to understand that if I overhang it off the end a tad, or under score it by a bit that this is just how it can be at times when I don't have the folder on the bench. I try. Sometimes the measurement devices are set for slightly off places because you squeeze them together and reset to zero and your zero might read .02 on mine or so. You never know. My point is I need some leeway to prevent having to make clips over if you'd prefer to not mail the folder.
Thanks
STR
Not a measurement, but a decent picture of the clip side.
Don't have the pattern and I'm not sure based on the picture how far apart the screws are exactly to determine if a fold over can fit between them still allowing for easy enough placement to take them off and on. The three hole pattern clip like used on Emersons, Spdyercos and many Benchmades is pretty tight though so if its not tighter spacing for those screws than that I would assume its quite possible yes.
Looks like a wonderful folder there. I have not seen it before today. I can see why you want a low rider though as the clip sets far too much out of the pocket for my tastes, particularly these days when you really don't want to be advertising you have a folder on you or drawing undue attention to yourself in many places.
Thanks for sharing that Josh.
STR
