Greetings "Blade 420":
My name is Rick Thatch. I am a Manufacturing/Engineering Technician hare at Benchmade Knife. What that translates into is that I get to make (and carry) all the prototypes and help in the design decisions for manufacturability. Recently, when we began the 49 Kris project, the blade grinding department was given the task of creating a flat ground kris blade. After more than a week, using multi million dollar machines, the team of grinding experts said that they could not do a kris in any kind of production quantity. Even the few that they produced were not of the quality that we demanded. That is when I took on the challenge. The result was the hollow ground kris that you have seen. I am proud to have been the one responsible for a grind that, to my knowledge, has never been done before. I also was given the task of creating the process for and machining the 49 handles and cocobolo inserts. The results you have seen in the 49-special.
I am telling you all this as a background to something that you may have an interest in. In the process of machining these components, being aware that I would purchase one of the 49-specials for myself, I began to pick and choose components throughout the run that would go into my Bali, the "private reserve" if you will. This, very special, 49 special will be going up for auction in the next few hours.
Here is what Chuck Gollnick wrote after seeing this Bali, #8 of 25.
"That is a very impressive piece
Certainly the 25 Benchmade 49-SPLs are about the finest and most collectible
knives that Benchmade has ever made. But, this one is the pick of the
litter. It's not just the gold-plated screws that set it apart, though
they're a nice touch. The blade channels in the handles were milled out
with a special milling tool, the tool that Benchmade wanted to use on all of
the 49s. This tool leaves a wonderfully smooth finish. Unfortunately, this
tool also proved unable to withstand the tools steel that these handles were
made on and it wore out in the middle of the very next handle they tried it
on. So, only one set of handles was made with this special tool. The
cocobolo wood for the inserts on this 49-SPL were hand-selected and are the
best of the lot. They display wonderful grain and depth. The gold and
honey tones in the wood tie in nicely with the gold-plated screws. And the
blade and the handles received an extra-special polishing job. Only 25
Benchmade 49-SPLs were made and each one is special. But, this one stands
above the rest."
Chuck Gollnick
The Balisong Collector
http://www.balisongcollector.com
I will send you a note with a link to the auction as soon as it is available.
Here are a few pics, more are available if you would like to see them.
Rick Thatch
Benchmade
