- Aug 27, 2004
My friend Ktint from up in New York has some knives here that are next up on the bench. I got two knives from him quite a while ago actually and one I knocked out today. Its a Mini Commader by Emerson with a new Talonite blade he had custom made for it by Reese Weiland.
I must admit Reese did an outstanding job on this and I am very impressed with both of these blades because he did another custom Talonite blade for this Buck Strider 881 folder.
Ktints needs were a request I have not had before. There have already been a lot of firsts on my forum so this should fit right in. His request for both is that they be 'hard to open'. You read that right. His original request was for bigger detent balls. On the mini Commander I simply drilled for activating the detent in the lock as well as the one that is active on it from the factory on the non lock side. So this one is effectively 'hard to open' now that this is done. No flicking this one open anymore thats for sure!
The second project is the one this thread is titled for.
Now this one required a bit more thought and it has been ongoing for a while now as I progress.
Long story short Ktint would like a better more secure grip for his 881 folder and for it to be a frame lock. Now I have tried this before with my own 881 and made some critical mistakes that caused me to waste titanium. This time I'm better prepared due to those past errors so we'll see how much I learned I guess.
Ktint's original request was for something like an SnG or his Mini Commander grip to keep his fingers from sliding up on it. Try as I might using the PT I own and his own Mini Commander as a template to get ideas from I can't seem to come up with anything quite like those due to ways in which those are built compared to this one but if you can use your imaginations with me here I think I have found a happy medium by incorporating a design I have been working on for one of my own customs down the road that will work I think with some slight modification to the shape and I am about ready to go for it.
This should be both challenging and if I pull it off another of many firsts here in the backyard. Then again it could be a miserable failure where I have to put it all back together as it came and admit defeat. Needless to say this is not for the faint at heart budget wise and its also going to require both non lock and lock side to be redone. The non lock side will be textured G10. I will let Ktint decide on which, ranger green, coyote brown or black. Let me know my friend.
Here are some beginning pics of what I have in mind for this 881 talonite beauty as well as a single quick scan of the Mini Commander with the new custom blade in it unless my friend Ktint decides to change my direction. We'll know more later on that.
In the mean time, stay tuned. This should be good!
STR
STR
