Built a finishing grinder for under 780.00 bucks
Just finishing up a finishing grinder.
It has a 14 inch wheel, 1 inch shaft running the wheel for stability, 2 inline bearings that are self alinging, and reduction pullys to make the torque right at low speeds!
The motor is only a 1 hp AC with ac vary drive I picked up from a fellow that builds them for me. Geex I figured out what I have in my other one (factory build)
1600 for the grinder and 280 for the wheel.
This will one will be a better grinder cheaper to boot!
What do you use?
Web Site At www.darrelralph.com
MADD MAXX !
that sounds great ralph, my first 2x72 was a coote with a 8". last fall i added a hardcore set up for flat and convex grinding. i dont like the hollow grinds you get from 8" and 10" wheels and have been concidering ordering a 14" for a while. that would make a strong radius. who did you get the 14" wheel from? the folks at tru-grit only go to 12". is it true that you can only run at slower speeds with the 14"?
Laurence Segal www.RHINOKNIVES.com
The wheels can be had at Koval Knives Special order about a month wait.
You can specifie the bore size.
Yes with a 14 you run almost twice the sfpm
as an 8 in wheel. I use reduction of 3 to one to get fast motor speed at slower speeds.
This works great for me!
The ac spindle control is a relience
The electrician sets them up with forward reverse and a speed pot.
I have been running one on a small mill for 6 years now. They run great.
1 hp motors area dime a dozen anymore!
MADD MAXX !
Darrel, how about a picture of the new piece of equipment.
I'm using a grizzly
grinds ok, Hogs very nicely, but lacking as it vibrates a little. Oh well, better than nothing, I think!
cant' typa at all todey! :P
[This message has been edited by Taz (edited 03-16-2001).]
I have some plates a fellow gave me cj.
They are .75 thick 1045 blanchard ground plates OH YA.
I built it on this plate for make it as stable as posible.
The big bearings make a difference when it comes to how smooth it runs. User p ground shafting for the drive!
MADD MAXX !
Darrell, were did you get the 14" wheel?
My grinder runs on 1-1/4" bearings with the wheel end turned down to 1". It runs real smooth, I don't have variable speed though.
Sola Fide
Yes the bearings ect
I like direct drive from a shaft. The bearing ID is 1 inch so it heavy duty!
Koval can get them from bader that will fit your machine!
MADD MAXX !
[This message has been edited by Darrel Ralph (edited 03-17-2001).]
