BushMaster tapered tang - pics!
Daniel Koster
www.kosterknives.com
I've now started the BushMaster Elites finally.....whew!
Here are some teaser pics....:p
Side view:
view of the underside (tip in the bottom left):
Booty pic: :D :eek: :p
These taper very nicely....but they are a PAIN to do....don't expect this ever again on any future runs!
So, why do I taper the tang? even though it's already lighter because of being skeletonized?
Here's why:
Blade as-is (standard BushMaster Blank) =
Weighs exactly 6.0 ounces.
Blade with a tapered tang =
Weighs 4.6 ounces.
That's a 25% weight reduction. What is already a fairly light, easy-to-carry knife now becomes an ultralight knife with a fullsize handle and full flat grind from 3/16" oversize CPM3V steel (read: TOUGH).
This is the most Blade-For-Buck you can get. It doesn't get any better than this in terms of Maximizing Function.
The Ironwood handles will just be icing on the cake. :D
Glue-up starts tomorrow!
Dan
2 hrs later.....
3 more tangs done.
Holy Crap....this is tougher than flat grinding Survivors!
:eek: :eek: :eek: :eek:
Dan
Holy Crap....I think I spent nearly the entire day today finishing up these tapered tangs. This is way too much work!
:o
Dan
I somehow finished the tapered tangs late last night. I wanted to shoot myself in BOTH feet. I wasn't sure I'd want to get out of bed this morning...but somehow managed it....:o
I'm sure it'll be worth it for you guys and I'll be able to look back someday and think "Oh....it wasn't really that bad".....
Someday....
:p
Dan
Pics for your enjoyment!
I have to use a special jig to do this and yes, I should build my own...but in the meantime, I can use the one at Tom's shop.
Here is a pic of the setup drilling the smaller holes:
attachment.php
And a pic showing the large hole after drilling:
attachment.php
Then I have to flip it over while the handle is still clamped on - in order to counterbore the handles.
attachment.php
So, by this time, you guys are probably wondering "Why all the fuss?".
Look here:
attachment.php
See the angle the handle slab is set at?
Normally, I can just clamp one handle slab to the tang, set it down on the stand and drill right through it. 3 times on a "F" (0.254") drill bit, once with a 3/8" bit.
But if I did that here, the holes drilled from both side would make a wide "V" instead of a straight line.
So, I have to clamp the knife in this jig that holds the knife by the blade ensuring that it's perpendicular to the drill bit and when the 2 slabs come together, the holes align in a straight line.
If that doesn't make sense...then you'll just have to trust me. :D
The difference is that it takes me about 8 times as long to drill the slabs for each knife.
Anyway....the first 10 are done now....:D
Have a look:
attachment.php
Will be glued-up today/tomorrow.
:thumbup:
Dan
Nice work. Seems like weight is often overlooked, which is OK for collection pieces, but critical if the knife will be carried along with other gear. I look for tapered tangs for balance also, along with good corrosion resistance (154CM or CPM-S30V are favorites) when considering a buy. The taper combined with skeletonization are a winner for me. Mailing list subscribed;)
