Originally posted by Brendan
What do I do if I have changed the original edge !!!
%£$% - what a frustrating thing !!
Guys I'm getting ready to leave on a trip early in the morning so I don't really have the time to walk all of you through sharpening a khuk right now, but maybe in a few days.
Just let me suffice to say this.....
Don't Worry about the %$#@$%$#@#$ Damned Edge Angle!!!!! Or the %^$#@@#$#@ Damned Original Edge!!!!
They don't mean a %%$#$#@#&^%$ Damned thing!!!!!!
There was no one around telling your great great great great great great great grandfather that he had to hold a consitent angle on a knife's edge and I damn well guarantee you he Knew how to sharpen anything that was used to cut and in those days the convex edge was KING!!!!
Left to a person's own devices they will always get a convex edge if they ignore all the hype put out by those who would make you think you have to have some damned kind of guide to hold a certain angle in order to sharpen a knife.
There's been more confusion over the khuk's edges since the kamis have went to power tools and consequently got lazy and started putting on an edge that's foreign to the khukuri.
The khukuri is supposed to have a
convex edge like an axe. A khukuri is a chopper plain and simple and should be sharpened like one!!!! What makes a convex edge is to extremely large radii meeting together in a reasonably shallow arc.
Take, say a coffee can and put it on a piece of paper. Draw a line around the can about 1/4 of the way or so, it doesn't have to be real accurate. Then move the can to the other side and draw around the can to intersect the two arcs.
If you can imagine that then you know what a convex edge is. It's simple, the strongest, and the easiest edge to put on a knife, axe, hoe, hatchet or khukuri period!!!!
And anyone of you can do it period!!!!
And yes, the 5160 steel at 58-61 Rc is probably the best knife steel anyone new to the world of really good steel has used, but it damn sure ain't near as bad or near as hard as some of the new fangled stainless steels that one has to use diamonds on to sharpen.
Anyone not being able to get a burr all along one side of the edge just isn't spending enough time on that one side.
Believe me it took
me years to learn that after being told hundreds of times that it was absolutely necessary to have it before I started on the other side.
The best advice to cure that problem is to use a Marks-A-Lot and mark the edge about 1/8" up, let it dry and then do what you normally do to sharpen any edge.
Where the ink has been honed off whether you're using sandpaper, a whetstone or any device is where you're trying to sharpen from.
If the ink isn't honed off the edge then you ain't doing it right so simply change the angle until the ink is honed off the edge.
Then mark it again and again until you get the burr all along the opposite side if you have to.
Only then do you go to the other side and do the same thing.
I could show all of you how to do this in maybe two minutes so guys it ain't that damned hard.
By holding the knife or hone at an angle anywhere between 10* to 20* and not trying to keep it even except how far up the side it goes you will and can sharpen anything and with most anything that's abrasive.
I used an old Oklahoma sandrock to sharpen a POS China made stainless knife for one of a Bud's kids one day.
Took me about 1/2 an hour, but that was because the knife didn't have an edge to begin with.
Come on guys you can do it, hell I learned and if I can anyone can.
